Raspberry Pi SATA HAT as an external storage
Hello!
I’m considering purchasing a Radxa SATA HAT for my Raspberry Pi 5 to connect four SSD drives and configure them in a RAID setup. My goal is to use this as an external storage for a Samba server and Plex.
I’m wondering if this setup is feasible alongside Home Assistant. Has anyone here tried a similar configuration? Maybe there is some other better solution for DIY NAS?
I would greatly appreciate any guidance, insights, or sources on how to set this up successfully.
Thank you in advance for your help!
Managed to give that HAT a go. Everything is working fine with HA after proper config and additional docker from host OS for auto-reassembling the RAID at the boot.
