Raspberry pi zero w + camera
Hi
I have pi zero w
i connected simple camera link to camera
I want to add it to HA and see live stream video
how I do it?
Check out motioneye. There is a motioneyeos and a motioneye plug-in in HA. You don’t necessarily have to use both but I can confirm that it will work if you do. The frame rate won’t be great though (due to the pi0 hardware limitations I believe).
OK thanks
what i need install in my pi zero ?
I was assuming you already had HA running on a separate setup. I was saying that if you had HA running on another computer, you can run the motioneye plugin there and you can install the motioneyeos onto the pi0. My frame rate w that setup was typically 4-5fpm with a 2-3s lag as well.
It may be possible to run HA on the zero and install the camera on the same system as well. I’ve never tried that. Honestly I don’t think I would even try bc it would most likely be so slow as to be unusable but again I’ve not done it so I can’t say for certain.
