Raspberry pi zero W hassio.io connection problem
is it normal that I have a problem with connection to hassio on raspberry pi zero w almost every day. Then I have to reset the devices?
Installed hassio on 2 different raspberry pi zero w with different sd cards. No change. Do you have any stable Hassio install?
I can’t imagine the problem is with Hass.io if you installed it twice on two different Raspberry Pi Zero.
What do you mean “connection problem?”
You can’t reach the web interface on 8123?
You can’t ping the device?
I can’t reach the web interface on 8123
Supervisor log
20-09-09 02:22:16 INFO (MainThread) [supervisor.host.services] Update service information
20-09-09 02:22:17 INFO (MainThread) [supervisor.host.network] Update local network information
20-09-09 02:22:19 INFO (MainThread) [supervisor.host.sound] Update PulseAudio information
Failed to load cookie file from cookie: No such file or directory
[s6-init] making user provided files available at /var/run/s6/etc...exited 0.
[s6-init] ensuring user provided files have correct perms...exited 0.
[fix-attrs.d] applying ownership & permissions fixes...
[fix-attrs.d] done.
[cont-init.d] executing container initialization scripts...
[cont-init.d] udev.sh: executing...
[02:35:48] INFO: Update udev information
[cont-init.d] udev.sh: exited 0.
[cont-init.d] done.
[services.d] starting services
[services.d] done.
[02:35:52] INFO: Start local supervisor watchdog...
20-09-09 02:36:12 INFO (MainThread) [__main__] Initialize Supervisor setup
20-09-09 02:36:13 INFO (MainThread) [supervisor.bootstrap] Initialize Supervisor Sentry
20-09-09 02:36:13 INFO (MainThread) [supervisor.bootstrap] Setup coresys for machine: raspberrypi
20-09-09 02:36:13 INFO (SyncWorker_0) [supervisor.docker.supervisor] Attach to Supervisor homeassistant/armhf-hassio-supervisor with version 242
20-09-09 02:36:14 INFO (MainThread) [__main__] Setup Supervisor
20-09-09 02:36:16 INFO (MainThread) [supervisor.host.info] Update local host information
20-09-09 02:36:16 INFO (MainThread) [supervisor.host.services] Update service information
20-09-09 02:36:17 INFO (MainThread) [supervisor.host.network] Update local network information
20-09-09 02:36:18 INFO (MainThread) [supervisor.host.sound] Update PulseAudio information
20-09-09 02:36:18 INFO (MainThread) [supervisor.host.apparmor] Load AppArmor Profiles: {'hassio-supervisor'}
20-09-09 02:36:18 INFO (MainThread) [supervisor.host.services] Reload local service hassos-apparmor.service
20-09-09 02:36:19 INFO (SyncWorker_0) [supervisor.docker.interface] Attach to homeassistant/armhf-hassio-dns with version 9
20-09-09 02:36:19 INFO (MainThread) [supervisor.plugins.dns] Start CoreDNS plugin
20-09-09 02:36:19 INFO (SyncWorker_0) [supervisor.docker.interface] Clean hassio_dns application
20-09-09 02:36:26 INFO (SyncWorker_0) [supervisor.docker.dns] Start DNS homeassistant/armhf-hassio-dns with version 9 - 172.30.32.3
20-09-09 02:36:26 INFO (MainThread) [supervisor.plugins.dns] Updated /etc/resolv.conf
20-09-09 02:36:26 INFO (SyncWorker_0) [supervisor.docker.interface] Attach to homeassistant/armhf-hassio-audio with version 17
20-09-09 02:36:27 INFO (MainThread) [supervisor.plugins.audio] Start Audio plugin
20-09-09 02:36:27 INFO (SyncWorker_0) [supervisor.docker.interface] Clean hassio_audio application
20-09-09 02:36:38 INFO (SyncWorker_0) [supervisor.docker.audio] Start Audio homeassistant/armhf-hassio-audio with version 17 - 172.30.32.4
20-09-09 02:36:38 INFO (SyncWorker_0) [supervisor.docker.interface] Attach to homeassistant/armhf-hassio-cli with version 26
20-09-09 02:36:38 INFO (MainThread) [supervisor.plugins.cli] Start cli plugin
20-09-09 02:36:38 INFO (SyncWorker_0) [supervisor.docker.interface] Clean hassio_cli application
20-09-09 02:36:53 INFO (SyncWorker_0) [supervisor.docker.cli] Start CLI homeassistant/armhf-hassio-cli with version 26 - 172.30.32.5
20-09-09 02:36:53 INFO (SyncWorker_0) [supervisor.docker.interface] Attach to homeassistant/armhf-hassio-multicast with version 3
20-09-09 02:36:53 INFO (MainThread) [supervisor.plugins.multicast] Start Multicast plugin
20-09-09 02:36:54 INFO (SyncWorker_0) [supervisor.docker.interface] Clean hassio_multicast application
20-09-09 02:37:02 INFO (SyncWorker_0) [supervisor.docker.multicast] Start Multicast homeassistant/armhf-hassio-multicast with version 3 - Host
20-09-09 02:37:02 INFO (MainThread) [supervisor.updater] Fetch update data from https://version.home-assistant.io/stable.json
20-09-09 02:37:05 INFO (SyncWorker_0) [supervisor.docker.interface] Attach to homeassistant/raspberrypi-homeassistant with version 0.114.4
20-09-09 02:37:05 INFO (MainThread) [supervisor.homeassistant.secrets] Load Home Assistant secrets: 1
20-09-09 02:37:06 INFO (MainThread) [supervisor.hassos] Detect HassOS 4.12 / BootSlot A
20-09-09 02:37:09 INFO (MainThread) [supervisor.store.git] Load add-on /data/addons/core repository
20-09-09 02:37:09 INFO (MainThread) [supervisor.store.git] Load add-on /data/addons/git/a0d7b954 repository
20-09-09 02:37:10 INFO (MainThread) [supervisor.store] Load add-ons from store: 66 all - 66 new - 0 remove
20-09-09 02:37:10 INFO (MainThread) [supervisor.addons] Found 4 installed add-ons
20-09-09 02:37:10 INFO (SyncWorker_1) [supervisor.docker.interface] Attach to homeassistant/armhf-addon-samba with version 9.2.0
20-09-09 02:37:11 INFO (SyncWorker_0) [supervisor.docker.interface] Attach to hassioaddons/chrony-armhf with version 1.1.0
20-09-09 02:37:11 INFO (SyncWorker_3) [supervisor.docker.interface] Attach to homeassistant/armhf-addon-configurator with version 5.0.0
20-09-09 02:37:11 INFO (SyncWorker_2) [supervisor.docker.interface] Attach to homeassistant/armhf-addon-mosquitto with version 5.1
20-09-09 02:37:12 INFO (MainThread) [supervisor.snapshots] Found 1 snapshot files
20-09-09 02:37:12 INFO (MainThread) [supervisor.discovery] Load 1 messages
20-09-09 02:37:12 INFO (MainThread) [supervisor.ingress] Load 0 ingress session
20-09-09 02:37:13 INFO (MainThread) [__main__] Run Supervisor
20-09-09 02:37:13 INFO (MainThread) [supervisor.api] Start API on 172.30.32.2
20-09-09 02:37:13 INFO (MainThread) [supervisor.hassos] Rauc: A - marked slot kernel.0 as good
20-09-09 02:37:13 INFO (MainThread) [supervisor.addons] Phase 'AddonStartup.INITIALIZE' start 0 add-ons
20-09-09 02:37:13 INFO (MainThread) [supervisor.addons] Phase 'AddonStartup.SYSTEM' start 2 add-ons
20-09-09 02:37:14 INFO (SyncWorker_3) [supervisor.docker.interface] Clean addon_core_mosquitto application
20-09-09 02:37:24 INFO (SyncWorker_3) [supervisor.docker.addon] Start Docker add-on homeassistant/armhf-addon-mosquitto with version 5.1
20-09-09 02:37:25 INFO (SyncWorker_2) [supervisor.docker.interface] Clean addon_a0d7b954_chrony application
20-09-09 02:37:39 INFO (SyncWorker_2) [supervisor.docker.addon] Start Docker add-on hassioaddons/chrony-armhf with version 1.1.0
20-09-09 02:37:44 INFO (MainThread) [supervisor.addons] Phase 'AddonStartup.SERVICES' start 1 add-ons
20-09-09 02:37:45 INFO (SyncWorker_3) [supervisor.docker.interface] Clean addon_core_samba application
20-09-09 02:37:53 INFO (SyncWorker_3) [supervisor.docker.addon] Start Docker add-on homeassistant/armhf-addon-samba with version 9.2.0
20-09-09 02:38:00 INFO (SyncWorker_3) [supervisor.docker.interface] Start homeassistant
20-09-09 02:38:01 INFO (MainThread) [supervisor.services.modules.mqtt] Set core_mosquitto as service provider for mqtt
20-09-09 02:38:05 INFO (MainThread) [supervisor.homeassistant.core] Wait until Home Assistant is ready
20-09-09 02:43:01 INFO (MainThread) [supervisor.homeassistant.api] Updated Home Assistant API token
20-09-09 02:44:23 INFO (MainThread) [supervisor.homeassistant.core] Detect a running Home Assistant instance
20-09-09 02:44:23 INFO (MainThread) [supervisor.addons] Phase 'AddonStartup.APPLICATION' start 1 add-ons
20-09-09 02:44:24 INFO (SyncWorker_1) [supervisor.docker.interface] Clean addon_core_configurator application
20-09-09 02:44:44 INFO (SyncWorker_1) [supervisor.docker.addon] Start Docker add-on homeassistant/armhf-addon-configurator with version 5.0.0
20-09-09 02:44:49 INFO (MainThread) [supervisor.misc.tasks] All core tasks are scheduled
20-09-09 02:44:49 INFO (MainThread) [supervisor.misc.hwmon] Started Supervisor hardware monitor
20-09-09 02:44:49 INFO (MainThread) [supervisor.core] Supervisor is up and running
20-09-09 02:44:49 INFO (MainThread) [supervisor.host.info] Update local host information
20-09-09 02:44:49 INFO (MainThread) [supervisor.updater] Fetch update data from https://version.home-assistant.io/stable.json
20-09-09 02:44:55 INFO (MainThread) [supervisor.host.services] Update service information
20-09-09 02:45:00 INFO (MainThread) [supervisor.host.network] Update local network information
20-09-09 02:45:07 INFO (MainThread) [supervisor.host.sound] Update PulseAudio information
Core log
2020-09-09 04:26:31 ERROR (MainThread) [hass_nabucasa.remote] Connection problem to snitun server
2020-09-09 04:26:46 ERROR (MainThread) [snitun.client.client_peer] Can't connect to SniTun server eu-central-1.ui.nabu.casa:443
2020-09-09 04:26:46 ERROR (MainThread) [hass_nabucasa.remote] Connection problem to snitun server
2020-09-09 04:26:54 ERROR (MainThread) [snitun.client.client_peer] Can't connect to SniTun server eu-central-1.ui.nabu.casa:443
2020-09-09 04:26:54 ERROR (MainThread) [hass_nabucasa.remote] Connection problem to snitun server
2020-09-09 04:27:00 ERROR (MainThread) [snitun.client.client_peer] Can't connect to SniTun server eu-central-1.ui.nabu.casa:443
2020-09-09 04:27:00 ERROR (MainThread) [hass_nabucasa.remote] Connection problem to snitun server
2020-09-09 04:27:14 ERROR (MainThread) [snitun.client.client_peer] Can't connect to SniTun server eu-central-1.ui.nabu.casa:443
2020-09-09 04:27:14 ERROR (MainThread) [hass_nabucasa.remote] Connection problem to snitun server
2020-09-09 04:27:29 ERROR (MainThread) [snitun.client.client_peer] Can't connect to SniTun server eu-central-1.ui.nabu.casa:443
2020-09-09 04:27:29 ERROR (MainThread) [hass_nabucasa.remote] Connection problem to snitun server
2020-09-09 04:27:40 WARNING (MainThread) [hass_nabucasa.iot] Unable to connect: Cannot connect to host cloud.nabucasa.com:443 ssl:default [Try again]
2020-09-09 04:27:43 ERROR (MainThread) [snitun.client.client_peer] Can't connect to SniTun server eu-central-1.ui.nabu.casa:443
2020-09-09 04:27:43 ERROR (MainThread) [hass_nabucasa.remote] Connection problem to snitun server
2020-09-09 04:27:53 ERROR (MainThread) [snitun.client.client_peer] Can't connect to SniTun server eu-central-1.ui.nabu.casa:443
2020-09-09 04:27:53 ERROR (MainThread) [hass_nabucasa.remote] Connection problem to snitun server
2020-09-09 04:28:12 ERROR (MainThread) [snitun.client.client_peer] Can't connect to SniTun server eu-central-1.ui.nabu.casa:443
2020-09-09 04:28:12 ERROR (MainThread) [hass_nabucasa.remote] Connection problem to snitun server
2020-09-09 04:28:27 ERROR (MainThread) [snitun.client.client_peer] Can't connect to SniTun server eu-central-1.ui.nabu.casa:443
2020-09-09 04:28:27 ERROR (MainThread) [hass_nabucasa.remote] Connection problem to snitun server
2020-09-09 04:28:39 ERROR (MainThread) [snitun.client.client_peer] Can't connect to SniTun server eu-central-1.ui.nabu.casa:443
2020-09-09 04:28:39 ERROR (MainThread) [hass_nabucasa.remote] Connection problem to snitun server
2020-09-09 04:28:46 ERROR (MainThread) [snitun.client.client_peer] Can't connect to SniTun server eu-central-1.ui.nabu.casa:443
2020-09-09 04:28:46 ERROR (MainThread) [hass_nabucasa.remote] Connection problem to snitun server
2020-09-09 04:28:52 ERROR (MainThread) [snitun.client.client_peer] Can't connect to SniTun server eu-central-1.ui.nabu.casa:443
2020-09-09 04:28:52 ERROR (MainThread) [hass_nabucasa.remote] Connection problem to snitun server
2020-09-09 04:29:12 ERROR (MainThread) [snitun.client.client_peer] Can't connect to SniTun server eu-central-1.ui.nabu.casa:443
2020-09-09 04:29:12 ERROR (MainThread) [hass_nabucasa.remote] Connection problem to snitun server
2020-09-09 04:29:19 ERROR (MainThread) [snitun.client.client_peer] Can't connect to SniTun server eu-central-1.ui.nabu.casa:443
2020-09-09 04:29:19 ERROR (MainThread) [hass_nabucasa.remote] Connection problem to snitun server
2020-09-09 04:29:32 ERROR (MainThread) [snitun.client.client_peer] Can't connect to SniTun server eu-central-1.ui.nabu.casa:443
2020-09-09 04:29:32 ERROR (MainThread) [hass_nabucasa.remote] Connection problem to snitun server
2020-09-09 04:29:43 ERROR (MainThread) [snitun.client.client_peer] Can't connect to SniTun server eu-central-1.ui.nabu.casa:443
2020-09-09 04:29:43 ERROR (MainThread) [hass_nabucasa.remote] Connection problem to snitun server
2020-09-09 04:30:02 ERROR (MainThread) [snitun.client.client_peer] Can't connect to SniTun server eu-central-1.ui.nabu.casa:443
2020-09-09 04:30:02 ERROR (MainThread) [hass_nabucasa.remote] Connection problem to snitun server
2020-09-09 04:30:17 ERROR (MainThread) [snitun.client.client_peer] Can't connect to SniTun server eu-central-1.ui.nabu.casa:443
2020-09-09 04:30:17 ERROR (MainThread) [hass_nabucasa.remote] Connection problem to snitun server
2020-09-09 04:30:36 ERROR (MainThread) [snitun.client.client_peer] Can't connect to SniTun server eu-central-1.ui.nabu.casa:443
2020-09-09 04:30:36 ERROR (MainThread) [hass_nabucasa.remote] Connection problem to snitun server
2020-09-09 04:30:47 ERROR (MainThread) [snitun.client.client_peer] Can't connect to SniTun server eu-central-1.ui.nabu.casa:443
2020-09-09 04:30:47 ERROR (MainThread) [hass_nabucasa.remote] Connection problem to snitun server
2020-09-09 04:30:57 ERROR (MainThread) [snitun.client.client_peer] Can't connect to SniTun server eu-central-1.ui.nabu.casa:443
2020-09-09 04:30:57 ERROR (MainThread) [hass_nabucasa.remote] Connection problem to snitun server
2020-09-09 04:31:10 ERROR (MainThread) [snitun.client.client_peer] Can't connect to SniTun server eu-central-1.ui.nabu.casa:443
2020-09-09 04:31:10 ERROR (MainThread) [hass_nabucasa.remote] Connection problem to snitun server
2020-09-09 04:31:24 ERROR (MainThread) [snitun.client.client_peer] Can't connect to SniTun server eu-central-1.ui.nabu.casa:443
2020-09-09 04:31:24 ERROR (MainThread) [hass_nabucasa.remote] Connection problem to snitun server
2020-09-09 04:31:41 ERROR (MainThread) [snitun.client.client_peer] Can't connect to SniTun server eu-central-1.ui.nabu.casa:443
2020-09-09 04:31:41 ERROR (MainThread) [hass_nabucasa.remote] Connection problem to snitun server
2020-09-09 04:31:48 ERROR (MainThread) [snitun.client.client_peer] Can't connect to SniTun server eu-central-1.ui.nabu.casa:443
2020-09-09 04:31:48 ERROR (MainThread) [hass_nabucasa.remote] Connection problem to snitun server
2020-09-09 04:32:03 ERROR (MainThread) [snitun.client.client_peer] Can't connect to SniTun server eu-central-1.ui.nabu.casa:443
2020-09-09 04:32:03 ERROR (MainThread) [hass_nabucasa.remote] Connection problem to snitun server
2020-09-09 04:32:16 ERROR (MainThread) [snitun.client.client_peer] Can't connect to SniTun server eu-central-1.ui.nabu.casa:443
2020-09-09 04:32:16 ERROR (MainThread) [hass_nabucasa.remote] Connection problem to snitun server
2020-09-09 04:32:28 ERROR (MainThread) [snitun.client.client_peer] Can't connect to SniTun server eu-central-1.ui.nabu.casa:443
2020-09-09 04:32:28 ERROR (MainThread) [hass_nabucasa.remote] Connection problem to snitun server
2020-09-09 04:32:37 WARNING (MainThread) [hass_nabucasa.iot] Cannot connect because unable to refresh token:
2020-09-09 04:32:46 ERROR (MainThread) [snitun.client.client_peer] Can't connect to SniTun server eu-central-1.ui.nabu.casa:443
2020-09-09 04:32:46 ERROR (MainThread) [hass_nabucasa.remote] Connection problem to snitun server
2020-09-09 04:33:06 ERROR (MainThread) [snitun.client.client_peer] Can't connect to SniTun server eu-central-1.ui.nabu.casa:443
2020-09-09 04:33:06 ERROR (MainThread) [hass_nabucasa.remote] Connection problem to snitun server
2020-09-09 04:33:15 ERROR (MainThread) [snitun.client.client_peer] Can't connect to SniTun server eu-central-1.ui.nabu.casa:443
2020-09-09 04:33:15 ERROR (MainThread) [hass_nabucasa.remote] Connection problem to snitun server
2020-09-09 04:33:25 ERROR (MainThread) [snitun.client.client_peer] Can't connect to SniTun server eu-central-1.ui.nabu.casa:443
2020-09-09 04:33:25 ERROR (MainThread) [hass_nabucasa.remote] Connection problem to snitun server
[fix-attrs.d] done.
[04:38:10] INFO: Update udev information
[cont-init.d] done.
[services.d] done.
2020-09-09 04:41:02 WARNING (MainThread) [homeassistant.loader] You are using a custom integration for hacs which has not been tested by Home Assistant. This component might cause stability problems, be sure to disable it if you experience issues with Home Assistant.
2020-09-09 04:41:24 WARNING (MainThread) [homeassistant.setup] Setup of recorder is taking over 10 seconds.
2020-09-09 04:41:39 WARNING (Recorder) [homeassistant.components.recorder] Ended unfinished session (id=18 from 2020-09-05 13:38:52.298722)
2020-09-09 04:41:56 WARNING (MainThread) [homeassistant.setup] Setup of person is taking over 10 seconds.
2020-09-09 04:41:56 WARNING (MainThread) [homeassistant.setup] Setup of config is taking over 10 seconds.
2020-09-09 04:41:56 WARNING (MainThread) [homeassistant.setup] Setup of api is taking over 10 seconds.
2020-09-09 04:42:19 WARNING (MainThread) [homeassistant.setup] Setup of hassio is taking over 10 seconds.
2020-09-09 04:42:29 WARNING (MainThread) [homeassistant.setup] Setup of cloud is taking over 10 seconds.
2020-09-09 04:43:01 WARNING (MainThread) [homeassistant.setup] Setup of input_select is taking over 10 seconds.
2020-09-09 04:43:01 WARNING (MainThread) [homeassistant.components.binary_sensor] Setup of binary_sensor platform cloud is taking over 10 seconds.
2020-09-09 04:43:01 WARNING (MainThread) [homeassistant.components.binary_sensor] Setup of binary_sensor platform updater is taking over 10 seconds.
2020-09-09 04:43:01 WARNING (MainThread) [homeassistant.setup] Setup of zeroconf is taking over 10 seconds.
2020-09-09 04:43:01 WARNING (MainThread) [homeassistant.setup] Setup of mobile_app is taking over 10 seconds.
2020-09-09 04:43:03 ERROR (MainThread) [snitun.client.client_peer] Challenge/Response error with SniTun server
2020-09-09 04:43:03 ERROR (MainThread) [hass_nabucasa.remote] Connection problem to snitun server
2020-09-09 04:43:04 ERROR (MainThread) [homeassistant.components.updater] Timeout fetching Home Assistant update data
2020-09-09 04:43:15 WARNING (MainThread) [homeassistant.components.weather] Setup of weather platform met is taking over 10 seconds.
2020-09-09 04:43:15 WARNING (MainThread) [homeassistant.components.device_tracker] Setup of device_tracker platform mobile_app is taking over 10 seconds.
2020-09-09 04:43:51 WARNING (MainThread) [homeassistant.bootstrap] Waiting on integrations to complete setup: hacs
2020-09-09 04:44:03 WARNING (Thread-5) [homeassistant.components.mqtt] Disconnected from MQTT server core-mosquitto:1883 (1)
2020-09-09 04:45:04 WARNING (Thread-5) [homeassistant.components.mqtt] Disconnected from MQTT server core-mosquitto:1883 (1)
2020-09-09 04:46:07 WARNING (Thread-5) [homeassistant.components.mqtt] Disconnected from MQTT server core-mosquitto:1883 (1)
Next time I check the ping and smb folder to see if it works when the web interface fails!
Not recommended hardware:
