Hello, I’m new here and also starting now with the home assistant so forgive my English and if there is already this question or should post in another topic. Come on, I have a raspberry pi2 installed on it the hassio, everything working normal without error log, but in a lack of energy I realized that it does not return to work, nor ping to the raspberry ip. If I restart it from the inside or if it turns off it returns normal, but in drops of energy it does not return, then I have to reinstall from the beginning, what can be? Has anyone had this problem? Thank you
Use a USB power supply to power it, not a mobile charger or a USB port on a device. The Pi2 needs a sustained 1.8A at 5V, which neither phone chargers or USB ports on devices will supply.
Hi Tinkerer, I’m using the original 5V 3000mA source. Will the files corrupt with a power outage?
Potentially yes. That’s always a risk regardless of the power supply - if you lose power suddenly then the file system can become corrupt.
Thank you, I will improve my electrical system so that there is no lack of energy for the raspberry. Thanks again.
