Raspberry Pi2b deprecation and me
I’m a fresh home-assistant adept. I just discovered it after buying an IKEA Inspelning. I wanted to try it without buying the Dirigera box. I got an usb sonoff P for Zigbee and Installed Dietpi Linux then HA through dietpi software.
Everything was almost automatic. Zigbee Sonoff key discovered in few seconds then my plug Inspelning too. And it works even through iOS application (after few parameters to write with vim through ssh)
But I discovered after few hours that the Pi2b was deprecated, that my home assistant was not a complete version and that it would be stopped in December.
My questions:
  • will my system continue to work? My needs are for now pretty simple or is security issues could arrive when not updated
  • I’m hesitating between
    • a mini pc n150 (cheaper than n97: the n97 is a bit more powerful but more expensive and 12w instead of 6w as I read). But could there be bios issue ? I would put HAOS instead of windows
    • a raspberry pi5. But a full raspberry with a good case and ventilator is more expensive
    • a complete kit pi CM5 with case included but the only one in stock is 4Go ram. Is it compatible enough ? Or mini pc is best?
For now I’m just going to install plugs and presence detectors but in the future I’d like to find a Zigbee video camera usable without configuration and a loud alarm.
Is it worth it or is it better to switch to the ikea proprietary Dirigera system? I’d prefer to use homeassistant if as easy as my first impression!
And sorry for my frenchy English without AI
Best regards
The N150 is a better choice than any Pi5
Go here…
Definitely go to N150. And install proxmox VM manager, with it you’ll be able to use more of your new N150 (you’ll be able to run other things beside HA, too). List of scripts (among others):
https://community-scripts.github.io/ProxmoxVE/scripts
What you currently have wont just stop in december. I expect that (like Windows 7 on a PC) there will be no more updates to the 32-bit version core of Home Assistant, and you may have trouble applying updates to other components. You will definitely want to upgrade, but it doesn’t have to be a great rush.
A newer more powerful computer is definitely desirable, especially as you add more devices, automations, etc. On the other hand Home Assistant is a fairly light load for a computer, so an older or fairly low spec computer can do the job.
Personally I upgraded from a RasPi 4 to a used SFF (small form factor) low-power ex-business PC i bought cheap on ebay. I especially like that PC hardware is so much easier to upgrade than a RasPi, and there is so much more software for x86-64 CPU. I even set it up running full HAOS in a virtual machine under proxmox … but haven’t thought of anything else to use another VM for :wink:
Thanks for your answers. I just ordered a cheap mini n150 with 12GO ddr5 and 512ssd for 110€ including fees. I think it’s a bigger computer for my needs but I will reach the addons in that way and stay up to date. I don’t think I’m goona keep windows because I don’t like security on windows and since I read that proxmox doesn’t allow access to addons.
I’ll ask another question about configuration in another thread. Regards
Proxmox, no. A HA OS VM on Proxmox : yes
Read again - there’s no need to create a fresh thread Installing Home Assistant OS using Proxmox 8
You can install HAOS (which allows addons) on Proxmox, while also having the flexibility to run those services independent of HA (so, not as addons) should you wish to.
If nothing else a good thing of running HA inside VM on proxmox is the ability to restart HAOS remotely. I did use that in the past when HA restart only didn’t work (i connect ro my proxmox via VPN).
Running HAOS directly requires to go to the device and physically cut the power.
But, there are other uses, like adblock, proxy… you can also have two HA instances - one real, other for testing.
I run HAOS (Home Assistant Operating System) in a proxmox Virtual Machine, including official HA add-ons (ESPHome Device Builder, Music Assistant, Node-RED, File Editor, Samba) and 11 unofficial HACS addons (including Bureau of Meterology (Australia), blind card, mini-graph card, multiple-entity-row, Spook and Tuya Local) without any issues.
Over the past 12 years HA has been evolving and grown so much that I doubt any one person can keep up with all the changes. Early methods to install Home Assistant required a high level of expertise with linux … but HAOS method has been improved, streamlined, and made so user-friendly that the other methods have finally been deprecated. You will probably still see advice which I think is either assuming that everyone else has (or is trying to attain) the same high expertise with linux, or essentially “this is the method I used years ago, so thats what you should do too”.
HAOS does all those things the other installation methods do (like using Docker containers) - but does it totally transparent to the user.
HACS doesn’t have addons. It has integrations.
