Hi all.
I just install hassio (hassos_rpi3-1.13.img)
and i have some problem when start Raspberry after installing image.
I can ping Raspberry ip (192.168.1.171), but does not have access to port 8123 and UI
If i try use command like hassio > homeassistan info in hass.io cli (version 1.4.0) i get message The HTTP request failed with the error: Get http://hassio/homeassistant/info: dial tcp 172.30.32.2:80 connect: connection refused
In host system (on raspberry) i can ping 172.30.32.2 and can ping my home router 192.168.1.1(OpenWrt)
Does somebody have any ideas wich log i should check?
