Raspberry PI4 built-in bluetooth interference with USB 3.0 SSD disk
I am using home assistant os on raspberry pi 4. Currently I have a couple of BLE devices (Xiaomi Temperature and Humidity sensors) which broadcast BLE signals.
These are captured with the built in wifi+bluetoth module on the raspberry.
But as my smart home is growing, and I am adding devices further from the pi, bluetooth range and reception is becoming a problem.
Does anyone have any experience with adding a bluetooth dongle to the pi?
Will these dongles work natively with home assistant?
I am running home assistant of an SSD disk. I discovered that when it is connected to a USB 3.0 port, the bluetooth range of the pi is significantly reduced. This is a known issue as far as I know with USB 3.0 ports as it is causing interference. The devices need to be really close to the pi for the built-in bluetooth module to pickup their BLE signals (<3 meters.)
If I move the devices within this range, they are picked up instantly in home assistant.
Also, i discovered that if I connect the SSD to a USB 2.0 port, they work as expected with larger range (~10 meters).
Would adding a bluetooth dongle to an usb extension cable solve the issue?
Anyone have any experience with this issue?
Any help appreciated.
Yes
Everybody with an RPI4 using USB3 with any kind of radio, being BT, Zigbee or ZWave.
The USB3 on RPI4 is an EM radiator :wink:
You can use an esp32 to capture their signals and send them to HA.
Running into the same EXACT issue. Did adding an additional BT usb dongle help?
I have a couple of BLE sensors from Xiaomi and Govee. Today morning, I added a USB 3.0 HDD enclosure to the PI4 to capture and store videos from my various IP cameras. Well, tonight I went to check all my measurements for the day. What I found is that none of my BLE sensors (all Govee and Xiaomi) beyond a 3 meter (~10ft) radius were reporting any data. They all stopped around the same time I connected the usb drive. As soon as I disconnect the drive, the sensors are able to communicate with the PI4. Connecting the drive to usb 2.0 interface works fine so for the time being thats what Ill do.
Switching to USB2 solved all my problems!
Could it be possible that they interfere in both directions? I ran the flexible IO tester to see how my external SSD (Samsung OEM on a Mokin case) performs with very random access and the the IOPs/s almost doubled on USB2—from ~500 to ~900.
Here’s the test, if your interested:
fio --name TEST --eta-newline=5s --filename=temp.file --rw=randrw --size=2g --iosize=10g --blocksize=4k --ioengine=libaio --fsvnc=1 --iodepth=1 --direct=1 --numjobs=8 --runtime=60 --group_reporting
Does anybody knows if same / similar bluetooth problems appear also on Raspberry pi 5 if an SSD is used?
I have no reason to believe it won’t exist. The reason is due to how close Bluetooth (2.4ghz) RF range is to the 3Ghz USB3 bus and you see it on pretty much any machine with USB3. So it flew for pretty much any box where you have an SSD on USB3. So the symptoms aren’t isolated to Pi.
Hi, thanks for the answer. But is on Radpberry5 SSD adapter also USB3 used as interface?
I had the same problems on my pi5. When I put the SSD in a 2.0 port my problems went away.
I am going to try and fix it with a faraday cage (Wrapping the SSD in aluminium foil).
