I am fairly new to home assistant, Raspberry Pi and networking.
I was previously using my Installation on a wifi setup, and tried to connect it using a LAN port from my switch but no ip address was assigned to the instance.
Here are the few things that i have tried.
Did a fresh install and connected lan, the cli load shows on the screen, but with no ip address for eth0.
2.Tried different cat5e cables, i am not sure how different are the cables i tried, nothing made a difference. I can find the device on my switch/network but no ip is assigned as well. -
Tried giving a static ip, not working.
Connected the ethernet to other devices ( windows 10 laptop), the ethernet works fine, so i assume its not the switch causing the issue.
But, things works if I put in the my-network config file with settings for wifi
I am using a full unifi network setup, every other device work except for the pi
Any help regarding this is appreciated,
Thank you!!
