Can someone tell me how to install the raspberry Power integration as the custom component is archived?
Every time i try to install the integration from the UI i get this screen:
How to integrate it NOT from the UI ?
Since this compoment is in the core it can only be installed over the UI.
Have you removed the custom component?
I already removed the custom component…
EDIT: I restarted after deleting completely the custom component and now, going to integrations fro the UI i cannot see anymore that integration…
EDIT2: I found it, as i have italian language it is under ‘controllo alimentazione’ and not under ‘raspberry Pi Power Checker’… Solved!
