I have a Raspberry 3+ with a case that has LCD screen. I want to run HA interface on the device itself. How can I add X and a Broser support to the base Image?
Thanks,
Thanks,
Which Broser and which base image?
TL;DR: Forget it. A raspberry pi 3 with only 1GB of RAM isn’t even capable running a full/modern browser engine without lagging…
You can’t using HA OS. HA OS has no desktop (headless only), so no browser. You need to install an OS with a desktop, and then either HA Docker Container, HA Supervised or HA Core
Tnanks.
I will first setup up my home automation, backup the database, and then rebuild the underlining machine. WIth the desktop option, I will restore the database.
