I am using the Raspberry Pi Imager with a Pi 5 to install Home Assistant. Today, Home Assistant offered me an upgrade which I did. After the upgrade Home Assistant didn’t boot anymore.
I see the following error message:
BOOT ERROR: code 7 - 'Kernel or device-tree not found or is not compatible'
This is the second time that this happened after an upgrade. I usually just reinstall my formatting the SD / installing Home Assistant again with the image tool.
- Can I still fix the installation or do I have to reinstall?
- Why does this keep happening? It does not look like that the problem is related to any configuration in Home Assistant but something with the Kernel image?
