RaspberryMatic can’t find any of my Homematic IP devices
My problem:
RaspberryMatic can’t find any of my Homematic IP devices.
My setup:
• Raspberry Pi 4 Model B; 4 GB
• Home Assistant OS 7.2
• Addons installed: File editor (5.3.3), RaspberryMatic CCU (3.61.7.20220115)
• Telekom branded Wireless Stick
What I have tried:
Followed Jens Maus’ installation guide ( https://github.com/jens-maus/RaspberryMatic/wiki/Installation-HomeAssistant ) closely except for the last part „Add a home assistant automation to connect to the raspberrymatic addon“, but I believe that this would not prevent RaspberryMatic to discover my Homematic IP devices.
Speaking of Homematic IP: I found out that the Telekom USB-Stick is lacking a firmware update and hence can not communicate with tradional BidCos-RF. However, since all devices I am planning to operate are Homematic IP (door locks and thermostats), this should not be an issue either.
A previous problem that I ran into previously was the length of the USB cable. Since I extended it, RaspberrryMatic can discover the stick and is offering to search for devices. Unfortunately without finding anything.
RaspberryMatic CCU Logs:
Mounting /data as /usr/local (Home Assistant Add-On): OK
Starting watchdog...
Identifying onboard hardware: oci, OK
Initializing RTC Clock: no hardware found
Running sysctl: OK
Checking for Factory Reset: not required
Checking for Backup Restore: not required
Initializing System: OK
Starting logging: OK
Init onboard LEDs: init, OK
Starting irqbalance: OK
Starting iptables: OK
Starting network: eth0: link up, fixed, firewall, inet up, 172.30.33.1, OK
Identifying Homematic RF-Hardware: ....HmRF: none, HmIP: HMIP-RFUSB-TK/USB, OK
Updating Homematic RF-Hardware: HMIP-RFUSB: 4.2.14=>4.4.16, ERROR (4.2.14 != 4.4.16); HMIP-RFUSB-TK: 4.2.14, OK
Starting hs485dLoader: disabled
Starting xinetd: OK
Starting eq3configd: OK
Starting lighttpd: OK
Starting ser2net: disabled
Starting ssdpd: OK
Starting ha-proxy: OK
Starting NUT services: disabled
Initializing Third-Party Addons: OK
Starting LGWFirmwareUpdate: ...OK
Setting LAN Gateway keys: OK
Starting hs485d: disabled
Starting multimacd: not required
Starting rfd: no BidCos-RF hardware found
Starting HMIPServer: ...........OK
Starting ReGaHss: .OK
Starting CloudMatic: OK
Starting NeoServer: disabled
Starting Third-Party Addons: OK
Starting crond: OK
Setup onboard LEDs: booted, OK
Supervisor Logs:
22-02-03 15:17:14 WARNING (MainThread) [supervisor.api.ingress] No valid ingress session None
22-02-03 15:17:20 WARNING (MainThread) [supervisor.api.ingress] No valid ingress session None
22-02-03 15:17:21 WARNING (MainThread) [supervisor.api.ingress] No valid ingress session None
22-02-03 15:21:01 INFO (MainThread) [supervisor.homeassistant.api] Updated Home Assistant API token
22-02-03 15:23:47 INFO (MainThread) [supervisor.backups.manager] Found 8 backup files
22-02-03 15:25:13 WARNING (MainThread) [supervisor.api.ingress] No valid ingress session None
22-02-03 15:46:01 INFO (MainThread) [supervisor.resolution.check] Starting system checks with state CoreState.RUNNING
22-02-03 15:46:01 INFO (MainThread) [supervisor.resolution.checks.base] Run check for IssueType.SECURITY/ContextType.CORE
22-02-03 15:46:01 INFO (MainThread) [supervisor.resolution.checks.base] Run check for IssueType.FREE_SPACE/ContextType.SYSTEM
22-02-03 15:46:01 INFO (MainThread) [supervisor.resolution.checks.base] Run check for IssueType.TRUST/ContextType.PLUGIN
22-02-03 15:46:01 INFO (MainThread) [supervisor.resolution.checks.base] Run check for IssueType.PWNED/ContextType.ADDON
22-02-03 15:46:01 INFO (MainThread) [supervisor.resolution.checks.base] Run check for IssueType.TRUST/ContextType.CORE
22-02-03 15:46:01 INFO (MainThread) [supervisor.resolution.checks.base] Run check for IssueType.TRUST/ContextType.SUPERVISOR
22-02-03 15:46:01 INFO (MainThread) [supervisor.resolution.check] System checks complete
22-02-03 15:46:01 INFO (MainThread) [supervisor.resolution.evaluate] Starting system evaluation with state CoreState.RUNNING
22-02-03 15:46:01 INFO (MainThread) [supervisor.resolution.evaluate] System evaluation complete
22-02-03 15:46:01 INFO (MainThread) [supervisor.resolution.fixup] Starting system autofix at state CoreState.RUNNING
22-02-03 15:46:01 INFO (MainThread) [supervisor.resolution.fixup] System autofix complete
Config Logs:
[547644701712] Disconnected: Did not receive auth message within 10 seconds
14:16:42 – (WARNUNG) Home Assistant WebSocket API - Die Nachricht ist zum ersten Mal um 14:16:42 aufgetreten und erscheint 2 mal
[0x917F:11:0x0006]: async_initialize: all attempts have failed: [DeliveryError('Request failed after 5 attempts: <Status.NWK_INVALID_REQUEST: 194>'), DeliveryError('Request failed after 5 attempts: <Status.NWK_INVALID_REQUEST: 194>'), DeliveryError('Request failed after 5 attempts: <Status.NWK_INVALID_REQUEST: 194>'), DeliveryError('Request failed after 5 attempts: <Status.NWK_INVALID_REQUEST: 194>')]
12:23:34 – (WARNUNG) Zigbee Home Automation - Die Nachricht ist zum ersten Mal um 12:23:34 aufgetreten und erscheint 2 mal
Error doing job: Task exception was never retrieved
12:23:12 – (FEHLER) /usr/src/homeassistant/homeassistant/runner.py - Die Nachricht ist zum ersten Mal um 12:23:00 aufgetreten und erscheint 2 mal
Failed to parse broken GeneralFrame(header=CommandHeader(id=0x9F, subsystem=Subsystem.ZDO, type=CommandType.AREQ), data=b'\xAC\x9A\x84\x09\x43') as <class 'zigpy_znp.types.commands.ZDO.ParentAnnceRsp.Callback'>
12:23:12 – (WARNUNG) /usr/local/lib/python3.9/site-packages/zigpy_znp/api.py - Die Nachricht ist zum ersten Mal um 12:23:00 aufgetreten und erscheint 2 mal
Setup of homematic is taking over 10 seconds.
12:22:44 – (WARNUNG) /usr/local/lib/python3.9/asyncio/events.py
Detected integration that accessed discovery_info.__contains__('ssdp_location') instead of discovery_info.upnp.__contains__('ssdp_location') or discovery_info.ssdp_headers.__contains__('ssdp_location'); this will fail in version 2022.6. Please report issue for upnp using this method at homeassistant/components/upnp/device.py, line 78: if ssdp.ATTR_SSDP_LOCATION not in headers:
12:22:40 – (WARNUNG) helpers/frame.py - Die Nachricht ist zum ersten Mal um 12:22:40 aufgetreten und erscheint 2 mal
Failed to initialize proxy for homeassistant-rf
12:22:34 – (WARNUNG) /usr/local/lib/python3.9/site-packages/pyhomematic/_hm.py - Die Nachricht ist zum ersten Mal um 12:22:34 aufgetreten und erscheint 2 mal
Extract from configuration.yaml:
homematic:
  interfaces:
    rf:
      host: de838cd8-raspberrymatic
      port: 2001
      resolvenames: json
      username: Admin
      password: supersecretpassword
    wired:
      port: 2000
      resolvenames: json
      username: Admin
    hmip:
      port: 2010
      resolvenames: json
      username: Admin
    groups:
      port: 9292
      resolvenames: json
      username: Admin
      path: /groups
  hosts:
    raspberrymatic:
      username: Admin
logger:
  default: debug
Does anyone know what I am missing here?
Update: I ordered a proper RF-USB-Stick and will try if this will be able to detect my Homematic IP devices. Will post here if it works out.
I was happy to find this thread, as I am experiencing quite the same Problem, but with the original RF-USB-Stick: Raspberrymatic says “Es wurde keinerlei nutzbares HomeMatic Funkmodul/LAN-Gateway für die
homematic oder homematicIP Kommunikation im System gefunden.” (sorry for German message output; translated to english: No usable Gateway device found). My log file is also quite similar as shown above, especially the log entry
Updating Homematic RF-Hardware: HMIP-RFUSB: =>4.4.16, ERROR ( != 4.4.16)
is also contained in my log file. As I am not an expert for HomematicIP, I would appreciate any helpful hint!
I get the exact same error message
It started after I switched from the old HomeMatic CCU add-on to Raspberrymatic.
Hope someone can help.
Finally, I found the simple reason for my problem: I forgot to disable protected mode for this addon. Now it´s working perfectly!
I still have problems connecting any HomeMaticIP device via a HMIP-RFUSB. I guess the protected mode thing is just relevant for GPIO based modules anyway. Does anyone else still have problems?
Try installing the nightly build (snapshot version), it solved the problem for me.
Have a look here: https://community.home-assistant.io/t/homematic-hmip-rfusb-no-devices-found-after-switch-to-raspberrymatic/392114/4?u=flux-i
Cheers,
Timo
