Hello, I switched my RaspberryMatic from my OpenMediaVault (also docker) to HomeAssistant. I use HMIP-RFUSB. I simply imported the backup from my other RaspberryMatic instance. So far, everything worked in HomeAssistent. I can also find new HM-IP devices through the learning process.
Unfortunately, I just can’t find the previously used HM-IP-HAP. I’ve also reset the HAP to factory defaults several times. I’ve enabled all ports in RaspberryMatic.
In the RaspberryMatic firewall settings, I’ve set all ports to open. All other services have full access. I’m desperate. Do I need to allow anything else somewhere else? Maybe in Home Assistant itself?
