Hi everyone!
I have a fresh install of Home Assistant Supervised, but RaspberryMatic HMIPServer keeps getting an error and I don’t know why.
Hardware:
Raspberry PI 3 B+
HMIP-RFUSB
Configuration:
Linux homesrv 6.1.0-rpi6-rpi-v8 #1 SMP PREEMPT Debian 1:6.1.58-1+rpt2 (2023-10-27) aarch64 GNU/Linux
/boot/commandline.txt includes systemd.unified_cgroup_hierarchy=false apparmor=1 security=apparmor
Other installed addons:
Duck DNS: 1.15.0
File Editor: 5.7.0
Mosquitto broker: 6.4.0
Zigbee2mqtt: 1.18.1-1
configuration.yaml
I tried different options:
- No homematic config
- homematic config
#homematic:
# interfaces:
# rf:
# host: 192.168.0.50
# port: 2001
# resolvenames: json
# username: !secret homematicccuuser
# password: !secret homematicccupw
# hmip:
# port: 2010
# groups:
# port: 9292
# path: /groups
# hosts:
# raspberrymatic:
Logs:
RaspberryMatic Log:
Mounting /data as /usr/local (Home Assistant Add-On): OK
Starting watchdog...
Identifying host system: oci, OK
Initializing RTC Clock: no hardware found
Running sysctl: OK
Checking for Factory Reset: not required
Checking for Backup Restore: not required
Initializing System: OK
Setup ca-certificates: OK
Starting logging: OK
Init onboard LEDs: init, OK
Starting irqbalance: OK
Starting iptables: OK
Starting network: eth0: link up, fixed, firewall, inet up, 172.30.33.1, OK
Identifying Homematic RF-Hardware: ....HmRF: HMIP-RFUSB/eQ-3 [email protected], HmIP: HMIP-RFUSB/eQ-3 [email protected], OK
Updating Homematic RF-Hardware: HMIP-RFUSB: 4.4.18, not necessary, OK
Starting hs485dLoader: disabled
Starting xinetd: OK
Starting eq3configd: Starting lighttpd: OK
Starting ser2net: disabled
Starting ssdpd: OK
Starting ha-proxy: OK
Starting NUT services: disabled
Initializing Third-Party Addons: OK
Starting LGWFirmwareUpdate: ...OK
Setting LAN Gateway keys: OK
Starting hs485d: disabled
Starting multimacd: ...OK
Starting rfd: ..OK
Starting HMIPServer: .......................................................................................................................................................ERROR
Starting ReGaHss: .OK
Starting CloudMatic: OK
Starting NeoServer: disabled
Starting Third-Party Addons: OK
Starting crond: OK
Setup onboard LEDs: booted, OK
Finished Boot: 3.71.12.20231020 (raspmatic_oci_arm)
Home Assistant Core Log:
Logger: pyhomematic._hm
Source: components/homematic/entity.py:262
First occurred: 4:28:59 PM (36 occurrences)
Last logged: 4:37:29 PM
RPCFunctions.jsonRpcPost: Exception: <urlopen error [Errno 111] Connection refused>
ServerThread.jsonRpcLogin: Unable to open session.
Supervisor logs:
23-11-25 16:26:25 INFO (MainThread) [supervisor.hardware.monitor] Detecting add hardware /dev/mmd_hmip - None
23-11-25 16:26:25 INFO (MainThread) [supervisor.hardware.monitor] Detecting add hardware /dev/mmd_bidcos - None
23-11-25 16:26:25 INFO (MainThread) [supervisor.docker.addon] Added cgroup permissions 'c 240:1 rwm' for device /dev/mmd_hmip to addon_de838cd8_raspberrymatic
23-11-25 16:26:25 INFO (MainThread) [supervisor.docker.addon] Added cgroup permissions 'c 240:2 rwm' for device /dev/mmd_bidcos to addon_de838cd8_raspberrymatic
23-11-25 16:26:31 INFO (MainThread) [supervisor.services.modules.mqtt] Set core_mosquitto as service provider for mqtt
23-11-25 16:26:36 INFO (MainThread) [supervisor.auth] Auth request from 'core_mosquitto' for 'mqttasset'
23-11-25 16:26:36 INFO (MainThread) [supervisor.auth] Home Assistant not running, checking cache
23-11-25 16:28:11 WARNING (MainThread) [supervisor.addons.addon] Timeout while waiting for addon RaspberryMatic CCU to start, took more than 120 seconds
23-11-25 16:28:12 INFO (MainThread) [supervisor.core] Start Home Assistant Core
23-11-25 16:28:12 INFO (SyncWorker_1) [supervisor.docker.manager] Starting homeassistant
docker container ls
docker container ls homesrv: Sat Nov 25 16:35:55 2023
CONTAINER ID IMAGE COMMAND CREATED STATUS PORTS
NAMES
07f42e167e0c zigbee2mqtt/zigbee2mqtt-armv7:1.18.1-1 "/init" 6 minutes ago Up 6 minutes 0.0.0.0:8485->8485/tcp, :::8485->8485/tcp
addon_7ad98f9c_zigbee2mqtt
b4158f37f320 homeassistant/armv7-addon-configurator:5.7.0 "/init" 6 minutes ago Up 6 minutes (healthy)
addon_core_configurator
6506721e2194 homeassistant/armv7-addon-duckdns:1.15.0 "/init /run.sh" 9 minutes ago Up 9 minutes
addon_core_duckdns
587bfdc7e8db ghcr.io/jens-maus/raspberrymatic:3.71.12.20231020 "/sbin/init" 9 minutes ago Up 9 minutes (unhealthy) 22/tcp, 80/tcp, 161/tcp, 443/tcp, 1900-1902/tcp, 1999-2001/tcp, 2010/tcp, 5987/tcp, 8088
/tcp, 8181/tcp, 9099/tcp, 9292-9293/tcp, 10000/tcp, 41999-42001/tcp, 42010/tcp, 43438-43439/tcp, 48181/tcp, 48899/tcp, 49292/tcp, 49880/tcp addon_de838cd8_raspberrymatic
fbbea12654e1 homeassistant/armv7-addon-mosquitto:6.4.0 "/init" 9 minutes ago Up 9 minutes 0.0.0.0:1883-1884->1883-1884/tcp, :::1883-1884->1883-1884/tcp, 0.0.0.0:8883-8884->8883-8
884/tcp, :::8883-8884->8883-8884/tcp addon_core_mosquitto
de150e629fa1 ghcr.io/home-assistant/aarch64-hassio-multicast:2023.06.2 "/init" 10 minutes ago Up 10 minutes
hassio_multicast
b73de77c3771 ghcr.io/home-assistant/aarch64-hassio-audio:2023.10.0 "/init" 10 minutes ago Up 10 minutes
hassio_audio
ef76ee14ca0f ghcr.io/home-assistant/aarch64-hassio-dns:2023.06.2 "/init" 10 minutes ago Up 10 minutes
hassio_dns
58d0ea6c659b ghcr.io/home-assistant/aarch64-hassio-cli:2023.10.0 "/init" 10 minutes ago Up 10 minutes
hassio_cli
7dfdeb568286 ghcr.io/home-assistant/raspberrypi3-homeassistant:2023.11.3 "/init" 14 hours ago Up 7 minutes
homeassistant
7768f8a1bb72 ghcr.io/home-assistant/aarch64-hassio-observer:2023.06.0 "/usr/bin/observer" 14 hours ago Up 10 minutes 0.0.0.0:4357->80/tcp, :::4357->80/tcp
hassio_observer
51fdedf02eb4 ghcr.io/home-assistant/aarch64-hassio-supervisor:latest "/init" 14 hours ago Up 10 minutes
hassio_supervisor
lsusb
lsusb
Bus 001 Device 004: ID 1b1f:c020 eQ-3 Entwicklung GmbH HmIP-RFUSB
Bus 001 Device 005: ID 0451:16a8 Texas Instruments, Inc. CC2531 ZigBee
Bus 001 Device 006: ID 0424:7800 Microchip Technology, Inc. (formerly SMSC)
Bus 001 Device 003: ID 0424:2514 Microchip Technology, Inc. (formerly SMSC) USB 2.0 Hub
Bus 001 Device 002: ID 0424:2514 Microchip Technology, Inc. (formerly SMSC) USB 2.0 Hub
Bus 001 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
I tried also without apparmor, I also tried with and without ModemManager
No luck. Any ideas?
