Hello guys!
I’m new here! I installed Home Assistant to connect there all my smart things and connect it to homekit. I was using Homebridge but it had some problems and not all things worked properly. When I was installing it, it took 10 min to show the webpage and next 40 min to load everything and then I was able to create an account. Now I restarted it and it took 20 min again. I tried to install it on 2 sd cards and I have the same problem. I haven’t installed any plugins/smart home things yet. With homebridge I didn’t have those problems. I use Raspberry 4 with Microsoft Phone’s charger(it’s working properly and it gives enough power), I have really fast internet, connected my device via ethernet cable. I have no idea what’s wrong with it. I care about this because it makes doing everything nearly impossible. Maybe it’s problem with Raspbery because it’s really hot and I don’t have case with cooiling system. BUT Homebridge was working properly and really fast
BTW I’m new to those things and it could be a little bit hard to program on this so could you explain everything step by step
Thanks for helping me
