RaspberryPi5 Power Button to Clean Shutdown HASSIO
The RaspberryPi5 (rpi5) board has an inbuilt power button. Raspberry Pi Desktop and Raspberry Pi OS Lite interact with this button to trigger a clean shutdown. I’m wondering if there’s a way to configure HASSIO to also trigger a clean shutdown when this button is pressed.
A single or double press while HASSIO is running doesn’t do anything that I can see. I think a long press does a hard shutdown but haven’t tested this. If HASSIO is shutdown (red light on rpi5 board) a single press starts it back up.
I’m using Home Assistant Core: 2024.3.0, Supervisor: 2024.02.1, OS: 12.0, Frontend: 20240306.0
