Hello, do we absolutely need raspbian lite to manually install home ass. I tried on latest raspbian full version (stretch) and was able to install ha in my home dir. But trying to install in the virtual env. Did not work… it failed to set the permissions correctly… in /svr, well i presume. Is the raspbian lite a must ? Thank’s jeanrocco
It works perfectly well with the latest full version of raspbian - I did it myself last Sunday because I was having some problems.
The setting of permissions for /srv is something that must be done manually, and it makes no difference as to which version of raspbian you are using…
Thank’s, I will give it another try … and come back with my issues if any !
