Raspi4 installation [FIXED]
I’m a little stuck installing Home Assistant on an 8GB Raspberry Pi 4, I know it takes way longer than 20 minutes so I don’t think my problem is patience!
I’m getting the following error when trying to install HAOS…
Error for http+docker://localhost/v1.43/images/ghcr.io/home-assistant/raspberrypi4-64-homeassistant:2024.1.2/json: Not Found ("No such image: [ghcr.io/home-assistant/raspberrypi4-64-homeassistant:2024.1.2](https://)")Then
24-01-07 00:18:46 WARNING (MainThread) [supervisor.homeassistant.core] Error on Home Assistant installation. Retry in 30sec
Then, after way more than 30 seconds it does this
[supervisor.docker.interface] Updating image ghcr.io/home-assistant/raspberrypi4-64-homeassistant:landingpage to ghcr.io/home-assistant/raspberrypi4-64-homeassistant:2024.1.2
[supervisor.docker.interface] Downloading docker image ghcr_io/home-assistant/raspberrypi4-64-homeassistant with tag 2024.1.2.
[supervisor.resolution.check] Starting system checks with state running
and, after an eternity waiting for all the checks and stuff it just keeps rinsing and repeating. Since it appears to be struggling to find an online image I’m not sure what I can do to help it succeed, I’ve tried re-flashing the image from the Raspberry Pi image builder, I’ve tried a different SD card, I’ve even changed the cable to the router but all to no avail, I even downloaded the image for etcher and tried flashing that but had no luck there either. I’m a newbie to all of this so it’s bound to be a stupid mistake on my part so any help would be appreciated.
[FIXED]
I didn’t actually do anything but leave it running the install, after a couple of days maybe the wind changed or something but it’s finally completed.
Following. I’m getting a similar error trying to upgrade HA Core from 2023.12.3 to 2024.1.2. The upgrade never finishes and eventually everything reboots back to prior state. I’m a newbie so any advice would be welcomed.
