Raspian Freshh Install - ConnectionResetError: [Errno 104] Connection reset by peer
Hi all,
I’m trying to install HA on raspian, using the available tutorial (https://home-assistant.io/docs/installation/raspberry-pi/)
Everything goes smooth until the step to install HomeAssistant itself (pip3 install homeassistant).
When I run this command I hit a huge error, and althouht I’ve searched in the forum and google itself, I did not find any solution.
I’ve already tried to delete the virtual env, and start-over but got the same result.
Can anyone can give a help?
This is the error:
Exception:
File “/srv/homeassistant/share/python-wheels/urllib3-1.19.1-py2.py3-none-any.whl/urllib3/connectionpool.py”, line 594, in urlopen
chunked=chunked)
File “/srv/homeassistant/share/python-wheels/urllib3-1.19.1-py2.py3-none-any.whl/urllib3/connectionpool.py”, line 350, in _make_request
self._validate_conn(conn)
File “/srv/homeassistant/share/python-wheels/urllib3-1.19.1-py2.py3-none-any.whl/urllib3/connectionpool.py”, line 837, in validate_conn
conn.connect()
File “/srv/homeassistant/share/python-wheels/urllib3-1.19.1-py2.py3-none-any.whl/urllib3/connection.py”, line 323, in connect
ssl_context=context)
File "/srv/homeassistant/share/python-wheels/urllib3-1.19.1-py2.py3-none-any.whl/urllib3/util/ssl
.py", line 324, in ssl_wrap_socket
return context.wrap_socket(sock, server_hostname=server_hostname)
File “/usr/lib/python3.5/ssl.py”, line 385, in wrap_socket
_context=self)
File “/usr/lib/python3.5/ssl.py”, line 760, in init
self.do_handshake()
File “/usr/lib/python3.5/ssl.py”, line 996, in do_handshake
self._sslobj.do_handshake()
File “/usr/lib/python3.5/ssl.py”, line 641, in do_handshake
File “/srv/homeassistant/lib/python3.5/site-packages/pip/basecommand.py”, line 215, in main
status = self.run(options, args)
File “/srv/homeassistant/lib/python3.5/site-packages/pip/commands/install.py”, line 353, in run
wb.build(autobuilding=True)
File “/srv/homeassistant/lib/python3.5/site-packages/pip/wheel.py”, line 749, in build
self.requirement_set.prepare_files(self.finder)
File “/srv/homeassistant/lib/python3.5/site-packages/pip/req/req_set.py”, line 380, in prepare_files
ignore_dependencies=self.ignore_dependencies))
File “/srv/homeassistant/lib/python3.5/site-packages/pip/req/req_set.py”, line 554, in _prepare_file
require_hashes
File “/srv/homeassistant/lib/python3.5/site-packages/pip/req/req_install.py”, line 278, in populate_link
self.link = finder.find_requirement(self, upgrade)
File “/srv/homeassistant/lib/python3.5/site-packages/pip/index.py”, line 465, in find_requirement
all_candidates = self.find_all_candidates(req.name)
File “/srv/homeassistant/lib/python3.5/site-packages/pip/index.py”, line 423, in find_all_candidates
for page in self._get_pages(url_locations, project_name):
File “/srv/homeassistant/lib/python3.5/site-packages/pip/index.py”, line 568, in _get_pages
page = self._get_page(location)
File “/srv/homeassistant/lib/python3.5/site-packages/pip/index.py”, line 683, in _get_page
return HTMLPage.get_page(link, session=self.session)
File “/srv/homeassistant/lib/python3.5/site-packages/pip/index.py”, line 792, in get_page
“Cache-Control”: “max-age=600”,
File “/srv/homeassistant/share/python-wheels/requests-2.12.4-py2.py3-none-any.whl/requests/sessions.py”, line 501, in get
return self.request(‘GET’, url, **kwargs)
File “/srv/homeassistant/lib/python3.5/site-packages/pip/download.py”, line 386, in request
return super(PipSession, self).request(method, url, *args, **kwargs)
File “/srv/homeassistant/share/python-wheels/requests-2.12.4-py2.py3-none-any.whl/requests/sessions.py”, line 488, in request
resp = self.send(prep, **send_kwargs)
File “/srv/homeassistant/share/python-wheels/requests-2.12.4-py2.py3-none-any.whl/requests/sessions.py”, line 609, in send
r = adapter.send(request, **kwargs)
File “/srv/homeassistant/share/python-wheels/CacheControl-0.11.7-py2.py3-none-any.whl/cachecontrol/adapter.py”, line 47, in send
resp = super(CacheControlAdapter, self).send(request, **kw)
File “/srv/homeassistant/share/python-wheels/requests-2.12.4-py2.py3-none-any.whl/requests/adapters.py”, line 423, in send
timeout=timeout
File “/srv/homeassistant/share/python-wheels/urllib3-1.19.1-py2.py3-none-any.whl/urllib3/connectionpool.py”, line 643, in urlopen
_stacktrace=sys.exc_info()[2])
File “/srv/homeassistant/share/python-wheels/urllib3-1.19.1-py2.py3-none-any.whl/urllib3/util/retry.py”, line 315, in increment
total -= 1
TypeError: unsupported operand type(s) for -=: ‘Retry’ and ‘int’
Apologies if by any chance, it’s a dummy question, but I’m new to this.
Thanks.
This is a network error, probably from the source of the packages. Try again later.
Confirmed, it was network problem on the source of the packages.
However, this was occurring for 48hrs now. Anyway, it’s working now.
Small update,
If anyone comes across the same issue, this as due to ipv6.
Once i disable it, all updates went smooth.
