Raspian hassio crashes
Recently I moved from normal installation to hassio on docker. As base system I am using raspian lite. Unfortunately something is wrong and every couple of hours everything crashes. I can not even ssh to raspian with putty. Ram usage in hassio is high(around 80%) but it was also the same before I moved to docker installation and previously such crashing didn`t happen. Any help would be grate.
Maybe sd corruption. I moved hassio to docker on my nas. Raspberry pi’s are a no go since 2 total sd card broke in the past years.
What do you mean by nas ? Sorry for maybe stupid question but I do not know what this means. In addition I added restarting of hassio each 5 hours and this crashing stopped. It must be some hassio fault not raspian or card I think.
Ok, i mean my qnap nas. Running hassio in a vm.
If the restart helps with hassio crash prevention it could me a memory issue. Can you log memory usage?
Why would you move from a normal installation to raspbian with ha supervised? It’s not supported for a reason.
