RaspPi install stuck
New Install of HA following HA instructions. 32Gb card. RaspPi 3a. Ethernet to network.
Seems like it’s not getting internet but everything else in my network works just fine. What’s the story?
Thanks!
Log File:
> s6-rc: info: service s6rc-oneshot-runner: starting
> s6-rc: info: service s6rc-oneshot-runner successfully started
> s6-rc: info: service fix-attrs: starting
> s6-rc: info: service fix-attrs successfully started
> s6-rc: info: service legacy-cont-init: starting
> cont-init: info: running /etc/cont-init.d/udev.sh
> [18:10:59] INFO: Using udev information from host
> cont-init: info: /etc/cont-init.d/udev.sh exited 0
> s6-rc: info: service legacy-cont-init successfully started
> s6-rc: info: service legacy-services: starting
> services-up: info: copying legacy longrun supervisor (no readiness notification)
> services-up: info: copying legacy longrun watchdog (no readiness notification)
> s6-rc: info: service legacy-services successfully started
> [18:10:59] INFO: Starting local supervisor watchdog...
> 22-06-02 18:11:08 INFO (MainThread) [__main__] Initializing Supervisor setup
> 22-06-02 18:11:08 INFO (MainThread) [supervisor.docker.network] Can't find Supervisor network, creating a new network
> 22-06-02 18:11:09 INFO (MainThread) [supervisor.bootstrap] Initializing Supervisor Sentry
> 22-06-02 18:11:09 INFO (MainThread) [supervisor.bootstrap] Seting up coresys for machine: raspberrypi3-64
> 22-06-02 18:11:09 INFO (SyncWorker_0) [supervisor.docker.supervisor] Attaching to Supervisor ghcr.io/home-assistant/aarch64-hassio-supervisor with version 2022.08.6
> 22-06-02 18:11:09 INFO (SyncWorker_0) [supervisor.docker.supervisor] Connecting Supervisor to hassio-network
> 22-06-02 18:11:10 INFO (MainThread) [supervisor.resolution.evaluate] Starting system evaluation with state CoreState.INITIALIZE
> 22-06-02 18:11:10 INFO (MainThread) [supervisor.resolution.evaluate] System evaluation complete
> 22-06-02 18:11:10 INFO (MainThread) [__main__] Setting up Supervisor
> 22-06-02 18:11:15 INFO (MainThread) [supervisor.api] Starting API on 172.30.32.2
> 22-06-02 18:11:15 INFO (MainThread) [supervisor.hardware.monitor] Started Supervisor hardware monitor
> 22-06-02 18:11:15 INFO (MainThread) [supervisor.dbus.manager] Load dbus interface io.hass.os
> 22-06-02 18:11:15 INFO (MainThread) [supervisor.dbus.manager] Load dbus interface org.freedesktop.systemd1
> 22-06-02 18:11:15 INFO (MainThread) [supervisor.dbus.manager] Load dbus interface org.freedesktop.login1
> 22-06-02 18:11:15 INFO (MainThread) [supervisor.dbus.manager] Load dbus interface org.freedesktop.hostname1
> 22-06-02 18:11:16 INFO (MainThread) [supervisor.dbus.manager] Load dbus interface org.freedesktop.timedate1
> 22-06-02 18:11:16 INFO (MainThread) [supervisor.dbus.manager] Load dbus interface org.freedesktop.NetworkManager
> 22-06-02 18:12:24 INFO (MainThread) [supervisor.dbus.manager] Load dbus interface de.pengutronix.rauc
> 22-06-02 18:12:24 INFO (MainThread) [supervisor.dbus.manager] Load dbus interface org.freedesktop.resolve1
> 22-06-02 18:12:24 INFO (MainThread) [supervisor.host.info] Updating local host information
> 22-06-02 18:12:25 INFO (MainThread) [supervisor.host.services] Updating service information
> 22-06-02 18:12:26 INFO (MainThread) [supervisor.host.sound] Updating PulseAudio information
> 22-06-02 18:12:26 INFO (MainThread) [supervisor.host.manager] Host information reload completed
> 22-06-02 18:12:26 INFO (MainThread) [supervisor.host.network] Updating local network information
> 22-06-02 18:17:10 INFO (MainThread) [supervisor.host.network] Updating local network information
> 22-06-02 18:19:55 INFO (MainThread) [supervisor.host.apparmor] Loading AppArmor Profiles: {'hassio-supervisor'}
> 22-06-02 18:20:00 WARNING (MainThread) [supervisor.utils.whoami] Can't fetch Whoami data: Cannot connect to host services.home-assistant.io:443 ssl:default [Try again]
> 22-06-02 18:20:00 WARNING (MainThread) [supervisor.core] Can't adjust Time/Date settings: Can't fetch Whoami data: Cannot connect to host services.home-assistant.io:443 ssl:default [Try again]
> 22-06-02 18:20:00 INFO (MainThread) [supervisor.docker.monitor] Started docker events monitor
> 22-06-02 18:20:00 INFO (SyncWorker_0) [supervisor.docker.interface] Found ghcr.io/home-assistant/aarch64-hassio-cli versions: [<AwesomeVersion CalVer '2022.08.0'>]
> 22-06-02 18:20:00 INFO (SyncWorker_0) [supervisor.docker.interface] Attaching to ghcr.io/home-assistant/aarch64-hassio-cli with version 2022.08.0
> 22-06-02 18:20:00 INFO (MainThread) [supervisor.plugins.cli] Starting CLI plugin
> 22-06-02 18:20:02 INFO (SyncWorker_0) [supervisor.docker.cli] Starting CLI ghcr.io/home-assistant/aarch64-hassio-cli with version 2022.08.0 - 172.30.32.5
> 22-06-02 18:20:02 INFO (SyncWorker_0) [supervisor.docker.interface] Found ghcr.io/home-assistant/aarch64-hassio-dns versions: [<AwesomeVersion CalVer '2022.04.1'>]
> 22-06-02 18:20:02 INFO (SyncWorker_0) [supervisor.docker.interface] Attaching to ghcr.io/home-assistant/aarch64-hassio-dns with version 2022.04.1
> 22-06-02 18:20:02 INFO (MainThread) [supervisor.plugins.dns] Starting CoreDNS plugin
> 22-06-02 18:20:05 INFO (SyncWorker_0) [supervisor.docker.dns] Starting DNS ghcr.io/home-assistant/aarch64-hassio-dns with version 2022.04.1 - 172.30.32.3
> 22-06-02 18:20:05 INFO (MainThread) [supervisor.plugins.dns] Updated /etc/resolv.conf
> 22-06-02 18:20:10 INFO (SyncWorker_0) [supervisor.docker.interface] Found ghcr.io/home-assistant/aarch64-hassio-audio versions: [<AwesomeVersion CalVer '2022.07.0'>]
> 22-06-02 18:20:10 INFO (SyncWorker_0) [supervisor.docker.interface] Attaching to ghcr.io/home-assistant/aarch64-hassio-audio with version 2022.07.0
> 22-06-02 18:20:10 INFO (MainThread) [supervisor.plugins.audio] Starting Audio plugin
> 22-06-02 18:20:12 INFO (SyncWorker_0) [supervisor.docker.audio] Starting Audio ghcr.io/home-assistant/aarch64-hassio-audio with version 2022.07.0 - 172.30.32.4
> 22-06-02 18:20:12 INFO (SyncWorker_0) [supervisor.docker.interface] Found ghcr.io/home-assistant/aarch64-hassio-observer versions: [<AwesomeVersion CalVer '2021.10.0'>]
> 22-06-02 18:20:12 INFO (SyncWorker_0) [supervisor.docker.interface] Attaching to ghcr.io/home-assistant/aarch64-hassio-observer with version 2021.10.0
> 22-06-02 18:20:13 INFO (MainThread) [supervisor.plugins.observer] Starting observer plugin
> 22-06-02 18:20:15 INFO (SyncWorker_0) [supervisor.docker.observer] Starting Observer ghcr.io/home-assistant/aarch64-hassio-observer with version 2021.10.0 - 172.30.32.6
> 22-06-02 18:20:15 INFO (SyncWorker_0) [supervisor.docker.interface] Found ghcr.io/home-assistant/aarch64-hassio-multicast versions: [<AwesomeVersion CalVer '2022.02.0'>]
> 22-06-02 18:20:15 INFO (SyncWorker_1) [supervisor.docker.interface] Attaching to ghcr.io/home-assistant/aarch64-hassio-multicast with version 2022.02.0
> 22-06-02 18:20:15 INFO (MainThread) [supervisor.plugins.multicast] Starting Multicast plugin
> 22-06-02 18:20:18 INFO (SyncWorker_1) [supervisor.docker.multicast] Starting Multicast ghcr.io/home-assistant/aarch64-hassio-multicast with version 2022.02.0 - Host
> 22-06-02 18:20:18 WARNING (MainThread) [supervisor.jobs] 'Updater.fetch_data' blocked from execution, no supervisor internet connection
> 22-06-02 18:20:18 INFO (MainThread) [supervisor.homeassistant.secrets] Loaded 0 Home Assistant secrets
> 22-06-02 18:20:18 INFO (SyncWorker_0) [supervisor.docker.interface] No version found for ghcr.io/home-assistant/raspberrypi3-64-homeassistant
> 22-06-02 18:20:18 INFO (MainThread) [supervisor.homeassistant.core] No Home Assistant Docker image ghcr.io/home-assistant/raspberrypi3-64-homeassistant found.
> 22-06-02 18:20:18 INFO (SyncWorker_1) [supervisor.docker.interface] Attaching to ghcr.io/home-assistant/raspberrypi3-64-homeassistant with version landingpage
> 22-06-02 18:20:18 INFO (MainThread) [supervisor.homeassistant.core] Using preinstalled landingpage
> 22-06-02 18:20:18 INFO (MainThread) [supervisor.homeassistant.core] Starting HomeAssistant landingpage
> 22-06-02 18:20:18 INFO (MainThread) [supervisor.homeassistant.module] Update pulse/client.config: /data/tmp/homeassistant_pulse
> 22-06-02 18:20:20 INFO (SyncWorker_1) [supervisor.docker.homeassistant] Starting Home Assistant ghcr.io/home-assistant/raspberrypi3-64-homeassistant with version landingpage
> 22-06-02 18:20:20 INFO (MainThread) [supervisor.os.manager] Detect Home Assistant Operating System 9.0 / BootSlot A
> 22-06-02 18:20:20 WARNING (MainThread) [supervisor.jobs] 'GitRepo.clone' blocked from execution, no supervisor internet connection
> 22-06-02 18:20:20 ERROR (MainThread) [supervisor.store] Can't add repository https://github.com/esphome/home-assistant-addon due to 'GitRepo.clone' blocked from execution, no supervisor internet connection
> 22-06-02 18:20:20 INFO (MainThread) [supervisor.resolution.module] Create new suggestion SuggestionType.EXECUTE_RELOAD - ContextType.STORE / 5c53de3b
> 22-06-02 18:20:20 INFO (MainThread) [supervisor.resolution.module] Create new issue IssueType.FATAL_ERROR - ContextType.STORE / 5c53de3b
> 22-06-02 18:20:20 ERROR (MainThread) [supervisor.store] Can't add repository https://github.com/hassio-addons/repository due to 'GitRepo.clone' blocked from execution, no supervisor internet connection
> 22-06-02 18:20:20 INFO (MainThread) [supervisor.resolution.module] Create new suggestion SuggestionType.EXECUTE_RELOAD - ContextType.STORE / a0d7b954
> 22-06-02 18:20:20 INFO (MainThread) [supervisor.resolution.module] Create new issue IssueType.FATAL_ERROR - ContextType.STORE / a0d7b954
> 22-06-02 18:20:20 ERROR (MainThread) [supervisor.store] Can't add repository core due to 'GitRepo.clone' blocked from execution, no supervisor internet connection
> 22-06-02 18:20:20 INFO (MainThread) [supervisor.resolution.module] Create new suggestion SuggestionType.EXECUTE_RELOAD - ContextType.STORE / core
> 22-06-02 18:20:20 INFO (MainThread) [supervisor.resolution.module] Create new issue IssueType.FATAL_ERROR - ContextType.STORE / core
> 22-06-02 18:20:20 INFO (MainThread) [supervisor.store] Loading add-ons from store: 0 all - 0 new - 0 remove
> 22-06-02 18:20:20 INFO (MainThread) [supervisor.addons] Found 0 installed add-ons
> 22-06-02 18:20:20 INFO (MainThread) [supervisor.backups.manager] Found 0 backup files
> 22-06-02 18:20:20 INFO (MainThread) [supervisor.discovery] Loaded 0 messages
> 22-06-02 18:20:20 INFO (MainThread) [supervisor.ingress] Loaded 0 ingress sessions
> 22-06-02 18:20:20 INFO (MainThread) [supervisor.resolution.check] Starting system checks with state CoreState.SETUP
> 22-06-02 18:20:20 INFO (MainThread) [supervisor.resolution.check] System checks complete
> 22-06-02 18:20:20 INFO (MainThread) [supervisor.resolution.evaluate] Starting system evaluation with state CoreState.SETUP
> 22-06-02 18:20:20 INFO (MainThread) [supervisor.resolution.evaluate] System evaluation complete
> 22-06-02 18:20:20 INFO (MainThread) [supervisor.jobs] 'ResolutionFixup.run_autofix' blocked from execution, system is not running - CoreState.SETUP
> 22-06-02 18:20:20 INFO (MainThread) [__main__] Running Supervisor
> 22-06-02 18:20:20 INFO (MainThread) [supervisor.os.manager] Rauc: A - marked slot kernel.0 as good
> 22-06-02 18:20:20 INFO (MainThread) [supervisor.addons] Phase 'AddonStartup.INITIALIZE' starting 0 add-ons
> 22-06-02 18:20:20 INFO (MainThread) [supervisor.addons] Phase 'AddonStartup.SYSTEM' starting 0 add-ons
> 22-06-02 18:20:20 INFO (MainThread) [supervisor.addons] Phase 'AddonStartup.SERVICES' starting 0 add-ons
> 22-06-02 18:20:20 INFO (MainThread) [supervisor.core] Skiping start of Home Assistant
> 22-06-02 18:20:20 INFO (MainThread) [supervisor.addons] Phase 'AddonStartup.APPLICATION' starting 0 add-ons
> 22-06-02 18:20:20 INFO (MainThread) [supervisor.misc.tasks] All core tasks are scheduled
> 22-06-02 18:20:20 INFO (MainThread) [supervisor.core] Supervisor is up and running
> 22-06-02 18:20:20 INFO (MainThread) [supervisor.homeassistant.core] Home Assistant setup
> 22-06-02 18:20:20 WARNING (MainThread) [supervisor.jobs] 'Updater.fetch_data' blocked from execution, no supervisor internet connection
> 22-06-02 18:20:20 WARNING (MainThread) [supervisor.homeassistant.core] Error on Home Assistant installation. Retry in 30sec
> 22-06-02 18:20:20 INFO (MainThread) [supervisor.host.info] Updating local host information
> 22-06-02 18:20:20 INFO (MainThread) [supervisor.resolution.check] Starting system checks with state CoreState.RUNNING
> 22-06-02 18:20:20 INFO (MainThread) [supervisor.resolution.checks.base] Run check for IssueType.PWNED/ContextType.ADDON
> 22-06-02 18:20:20 INFO (MainThread) [supervisor.jobs] 'CheckAddonPwned.run_check' blocked from execution, no supervisor internet connection
> 22-06-02 18:20:20 INFO (MainThread) [supervisor.resolution.checks.base] Run check for IssueType.DNS_SERVER_IPV6_ERROR/ContextType.DNS_SERVER
> 22-06-02 18:20:20 INFO (MainThread) [supervisor.jobs] 'CheckDNSServerIPv6.run_check' blocked from execution, no supervisor internet connection
> 22-06-02 18:20:20 INFO (MainThread) [supervisor.resolution.checks.base] Run check for IssueType.IPV4_CONNECTION_PROBLEM/ContextType.SYSTEM
> 22-06-02 18:20:20 INFO (MainThread) [supervisor.resolution.checks.base] Run check for IssueType.TRUST/ContextType.SUPERVISOR
> 22-06-02 18:20:21 INFO (MainThread) [supervisor.host.services] Updating service information
> 22-06-02 18:20:22 INFO (MainThread) [supervisor.host.network] Updating local network information
> 22-06-02 18:20:35 WARNING (MainThread) [supervisor.utils.codenotary] Timeout while processing CodeNotary
> 22-06-02 18:20:35 INFO (MainThread) [supervisor.resolution.module] Create new suggestion SuggestionType.EXECUTE_INTEGRITY - ContextType.SYSTEM / None
> 22-06-02 18:20:35 INFO (MainThread) [supervisor.resolution.module] Create new issue IssueType.TRUST - ContextType.SYSTEM / None
> 22-06-02 18:20:35 INFO (MainThread) [supervisor.resolution.checks.base] Run check for IssueType.DNS_SERVER_FAILED/ContextType.DNS_SERVER
> 22-06-02 18:20:35 INFO (MainThread) [supervisor.jobs] 'CheckDNSServer.run_check' blocked from execution, no supervisor internet connection
> 22-06-02 18:20:35 INFO (MainThread) [supervisor.resolution.checks.base] Run check for IssueType.FREE_SPACE/ContextType.SYSTEM
> 22-06-02 18:20:35 INFO (MainThread) [supervisor.resolution.module] Create new suggestion SuggestionType.CREATE_FULL_BACKUP - ContextType.SYSTEM / None
> 22-06-02 18:20:35 INFO (MainThread) [supervisor.resolution.checks.base] Run check for IssueType.SECURITY/ContextType.CORE
> 22-06-02 18:20:35 INFO (MainThread) [supervisor.resolution.check] System checks complete
> 22-06-02 18:20:35 INFO (MainThread) [supervisor.resolution.evaluate] Starting system evaluation with state CoreState.RUNNING
> 22-06-02 18:20:50 WARNING (MainThread) [supervisor.jobs] 'Updater.fetch_data' blocked from execution, no supervisor internet connection
> 22-06-02 18:20:50 WARNING (MainThread) [supervisor.homeassistant.core] Error on Home Assistant installation. Retry in 30sec
> 22-06-02 18:20:51 WARNING (MainThread) [supervisor.utils.codenotary] Timeout while processing CodeNotary
> 22-06-02 18:20:51 INFO (MainThread) [supervisor.resolution.evaluate] System evaluation complete
> 22-06-02 18:20:51 INFO (MainThread) [supervisor.resolution.fixup] Starting system autofix at state CoreState.RUNNING
> 22-06-02 18:20:51 WARNING (MainThread) [supervisor.jobs] 'FixupSystemExecuteIntegrity.process_fixup' blocked from execution, no supervisor internet connection
> 22-06-02 18:20:51 WARNING (MainThread) [supervisor.jobs] 'FixupStoreExecuteReload.process_fixup' blocked from execution, no supervisor internet connection
> 22-06-02 18:20:51 INFO (MainThread) [supervisor.resolution.fixup] System autofix complete
> 22-06-02 18:21:20 WARNING (MainThread) [supervisor.jobs] 'Updater.fetch_data' blocked from execution, no supervisor internet connection
> 22-06-02 18:21:20 WARNING (MainThread) [supervisor.homeassistant.core] Error on Home Assistant installation. Retry in 30sec
> 22-06-02 18:21:50 WARNING (MainThread) [supervisor.jobs] 'Updater.fetch_data' blocked from execution, no supervisor internet connection
> 22-06-02 18:21:50 WARNING (MainThread) [supervisor.homeassistant.core] Error on Home Assistant installation. Retry in 30sec
> 22-06-02 18:22:20 WARNING (MainThread) [supervisor.jobs] 'Updater.fetch_data' blocked from execution, no supervisor internet connection
> 22-06-02 18:22:20 WARNING (MainThread) [supervisor.homeassistant.core] Error on Home Assistant installation. Retry in 30sec
> 22-06-02 18:22:50 WARNING (MainThread) [supervisor.jobs] 'Updater.fetch_data' blocked from execution, no supervisor internet connection
> 22-06-02 18:22:50 WARNING (MainThread) [supervisor.homeassistant.core] Error on Home Assistant installation. Retry in 30sec
> 22-06-02 18:23:20 WARNING (MainThread) [supervisor.jobs] 'Updater.fetch_data' blocked from execution, no supervisor internet connection
> 22-06-02 18:23:20 WARNING (MainThread) [supervisor.homeassistant.core] Error on Home Assistant installation. Retry in 30sec
> 22-06-02 18:23:50 WARNING (MainThread) [supervisor.jobs] 'Updater.fetch_data' blocked from execution, no supervisor internet connection
> 22-06-02 18:23:50 WARNING (MainThread) [supervisor.homeassistant.core] Error on Home Assistant installation. Retry in 30sec
Same here.
My whole LAN works fine, except Homeassistant Raspi.
Endless message:
22-10-02 14:48:38 WARNING (MainThread) [supervisor.homeassistant.core] Error on Home Assistant installation. Retry in 30sec
Standby :slight_smile:
I’m in exactly the same place! Tried numerous fresh installs and bought a new SD that is the recommended spec. Just doesn’t seem to see the network. Yet if I put in a card with other systems and boot, it’s working perfectly.
Same place here. RPI4, fresh SD card, HA 9.2…
With some research, I found that can be related to the date/time being wrong at boot. But cince I’m running it headless and I don’t foind anyway to connect via SSH, I’m stuck.
And not only it’s not working, but it also make some weird request on my network (Windows PC, PfSense gateway). Each time I connect the RPi, My dns resolution goes south. It like the RPi is broacasting some kind of ipv6 advertisement saying that he is also a DNS server…
So, I will continue to do some testing, but having a working ssh connection at boot will be really helpful.
I have a theory: my home network is in the range 172.17.1.x and since this is the same range as the internal docker, ha is no happy (and so is my network).
I will test that theory but first I have to setup a new switch with vlans :slight_smile:
Same issue, as a new user, totally dunno why this issue is difficult to fix…
Getting no clue to solve this problem as i just want to use home assistant not become an expert in Linux…
Hi, I have the same issue. Did anyone find the solution?
The only think that worked for me was going to a RasPi 4
