Ratgdo Question
Does the Ratgdo device replace the garage doors wifi or is it an add on? Will the myQ app still work and will Amazon key delivery still be available?
It does replace the wifi of the door.
No, A Key will not work. It bypasses the MyQ crap and does it right! No ‘cloud’ stuff from what I have seen.
If you want to keep MyQ active, ratgdo will not replace or inhibit MyQ at all. MyQ and ratgdo can both be active at the same time. A lot of folks disable/block MyQ, but you don’t have to.
The opener basically sees ratgdo as a second wall panel.
