I have the Same Error 500 Internal Server Error Server got itself in trouble … Help please
Which version are you using ?
If you add the repository in GitHub - vincentwolsink/py-agua-iot: py-agua-iot provides controlling heating devices connected via the IOT Agua platform of Micronova to HACS you will get the latest version then it should work.
Thank you very much, I managed to set it up!
At the moment, however, I do not see available entities, but only the device.I do not see
