I have the pellet stove (Anselmo Cola) with the same WiFi module. I try the custom component by Frederic Van Linthoudt (GitHub - fredericvl/py-agua-iot: py-agua-iot provides controlling heating devices connected via the IOT Agua platform of Micronova) but without success. I can configure the connection with this data:
But I have “Unknown error occurred” and thi is in my log file:
2021-12-18 23:53:30 ERROR (MainThread) [aiohttp.server] Error handling request
File "/usr/local/lib/python3.9/site-packages/aiohttp/web_protocol.py", line 435, in _handle_request
resp = await request_handler(request)
File "/usr/local/lib/python3.9/site-packages/aiohttp/web_app.py", line 504, in _handle
resp = await handler(request)
File "/usr/local/lib/python3.9/site-packages/aiohttp/web_middlewares.py", line 117, in impl
return await handler(request)
File "/usr/src/homeassistant/homeassistant/components/http/security_filter.py", line 60, in security_filter_middleware
File "/usr/src/homeassistant/homeassistant/components/http/forwarded.py", line 98, in forwarded_middleware
File "/usr/src/homeassistant/homeassistant/components/http/request_context.py", line 28, in request_context_middleware
File "/usr/src/homeassistant/homeassistant/components/http/ban.py", line 78, in ban_middleware
File "/usr/src/homeassistant/homeassistant/components/http/auth.py", line 181, in auth_middleware
File "/usr/src/homeassistant/homeassistant/components/http/view.py", line 137, in handle
result = await result
File "/usr/src/homeassistant/homeassistant/components/config/config_entries.py", line 157, in post
return await super().post(request, flow_id)
File "/usr/src/homeassistant/homeassistant/components/http/data_validator.py", line 62, in wrapper
result = await method(view, request, *args, **kwargs)
File "/usr/src/homeassistant/homeassistant/helpers/data_entry_flow.py", line 110, in post
result = await self._flow_mgr.async_configure(flow_id, data)
File "/usr/src/homeassistant/homeassistant/data_entry_flow.py", line 252, in async_configure
result = await self._async_handle_step(flow, cur_step["step_id"], user_input)
File "/usr/src/homeassistant/homeassistant/data_entry_flow.py", line 325, in _async_handle_step
result: FlowResult = await getattr(flow, method)(user_input)
File "/config/custom_components/aguaiot/config_flow.py", line 67, in async_step_user
await self.hass.async_add_executor_job(agua_iot, api_url, customer_code, email, password, gen_uuid, login_api_url, brand_id)
File "/usr/local/lib/python3.9/concurrent/futures/thread.py", line 52, in run
File "/usr/local/lib/python3.9/site-packages/py_agua_iot/__init__.py", line 92, in __init__
self._login()
File "/usr/local/lib/python3.9/site-packages/py_agua_iot/__init__.py", line 96, in _login
self.login()
File "/usr/local/lib/python3.9/site-packages/py_agua_iot/__init__.py", line 186, in login
claimset = jwt.decode(res['token'], verify=False)
File "/usr/local/lib/python3.9/site-packages/jwt/api_jwt.py", line 119, in decode
decoded = self.decode_complete(jwt, key, algorithms, options, **kwargs)
File "/usr/local/lib/python3.9/site-packages/jwt/api_jwt.py", line 86, in decode_complete
raise DecodeError(
jwt.exceptions.DecodeError: It is required that you pass in a value for the "algorithms" argument when calling decode().
Can someone find where is the problem or help me solve it?
