I was wondering if there is a way to access the Raw UI Editor file with another editor.
Like VScode or notepad ++, so i can use find/replace and stuff.
If i edit the lovelace file in storage i need to restart for changes to take effect, plus it’s encoded in json (or something)
Any way i can access the file through samba?
Or is there any good code editor chrome addons?
On the subject: i have all these set up already.
I want to use a capable code editor to access the same file that pops up when we go to Edit UI -> Raw configuration editor
Is that possible?
Not unless you are using YAML mode. If you are editing Lovelace in the UI mode the settings are saved as json not yaml. They are only converted when you open / save the raw edit mode.
When I need to do this I just copy / paste from the raw edit window.
24 hours sunlight messes with my sleep patterns quite badly.
