HI.
I have a new problem with my Z-Wave Controller. Since the last update, I have this issue:
2020-06-02 03:27:39.441 Always, OpenZwave Version 1.4.3469 Starting Up
2020-06-02 03:27:57.636 Info, Setting Up Provided Network Key for Secure Communications
2020-06-02 03:27:57.636 Info, mgr, Added driver for controller /dev/ttyAMA0
2020-06-02 03:27:57.636 Info, Opening controller /dev/ttyAMA0
2020-06-02 03:27:57.637 Info, Trying to open serial port /dev/ttyAMA0 (attempt 1)
2020-06-02 03:27:57.638 Info, Serial port /dev/ttyAMA0 opened (attempt 1)
2020-06-02 03:27:57.639 Detail, contrlr, Queuing (Command) FUNC_ID_ZW_GET_VERSION: 0x01, 0x03, 0x00, 0x15, 0xe9
2020-06-02 03:27:57.639 Detail, contrlr, Queuing (Command) FUNC_ID_ZW_MEMORY_GET_ID: 0x01, 0x03, 0x00, 0x20, 0xdc
2020-06-02 03:27:57.639 Detail, contrlr, Queuing (Command) FUNC_ID_ZW_GET_CONTROLLER_CAPABILITIES: 0x01, 0x03, 0x00, 0x05, 0xf9
2020-06-02 03:27:57.639 Detail, contrlr, Queuing (Command) FUNC_ID_SERIAL_API_GET_CAPABILITIES: 0x01, 0x03, 0x00, 0x07, 0xfb
2020-06-02 03:27:57.639 Detail, contrlr, Queuing (Command) FUNC_ID_ZW_GET_SUC_NODE_ID: 0x01, 0x03, 0x00, 0x56, 0xaa
2020-06-02 03:27:57.639 Info, contrlr, Sending (Command) message (Callback ID=0x00, Expected Reply=0x15) - FUNC_ID_ZW_GET_VERSION: 0x01, 0x03, 0x00, 0x15, 0xe9
2020-06-02 03:27:57.639 Detail, contrlr, Notification: DriverFailed
System: HassOS 4.8
Supervisor: 225
What is happening? I’ve never had a problem with my Razberry controller
