RBG Color numbers for the brightest light?
I have an LED light with Tasmota installed. I have the RGB set to 255,255,255 which is a dull white. In playing around with the color settings in Tasmota I am able to get the light brighter by moving the sliders left and right and just playing around with it. I cant though translate that playing around into a set of numbers that I can use to input into the yaml. Can someone tell me what RBG numbers they use to get the brightest lights?
brightness: 255
Hi, you can use the developer tools: Developer Tools -> States.
Enter the entity-id and you can see all attributes of the light, including RGB values, when it is turned on.
Thank you very much!
