Was playing around with a rdm6300 reader with esphome.
But have issues with it not reacting at all.
To make sure that the reader is working I connected it directly to a USB-UART and can see in Termite that the reader spams the tag-id as long as I have e tag near the antenna. so the reader works.
On esphome there is no signs of life.
Inside common i have WIFI, OTA and API settings
esphome:
platform: ESP8266
board: esp12e
<<: !include common/common_ex_logger.yaml
logger:
level: VERY_VERBOSE
baud_rate: 0
uart:
rx_pin: GPIO3
baud_rate: 9600
rdm6300:
I use a bare esp12 on a devboard.
The TX pin on the reader is connected to the RX pin on the ESP12
If I have understood the documentation correctly on https://esphome.io/components/binary_sensor/rdm6300.html
I should have received: Found new tag with ID ‘XXXXXXX’
Any ideas?
