In https://github.com/AlexMekkering/Hass-Mqtt-Esp8266-Pins I created a collection of (re-)configurable MicroPython scripts for ESP8266 boards which expose their GPIO pins by using MQTT topics which comply with Home Assistant’s MQTT discovery protocol (starting with Home Assistant 0.48).
My main goals of this all were:
- to have a common code base for all my ESP8266 boards
- it’s easy to install
- it’s configurable per ESP8266 board
- it supports Home Assistant’s MQTT discovery
Currently it supports switches and lights, but I tend to extend this to sensors and binary sensors also.
It’s interactively configurable.
Installation
TL;DR for ESP8266 on /dev/ttyUSB0
Installation of Hass-Mqtt-Esp8266-Pins can be as simple as:
- Flash the MicroPython firmware on the ESP8266 board by following https://docs.micropython.org/en/latest/esp8266/esp8266/tutorial/intro.html
esptool.py --port /dev/ttyUSB0 erase_flash esptool.py --port /dev/ttyUSB0 --baud 460800 write_flash --flash_size=detect 0 esp8266-20170612-v1.9.1.bin
- Copy .py files from the src folder to the ESP8266 board
git clone https://github.com/AlexMekkering/Hass-Mqtt-Esp8266-Pins.git ampy -p /dev/ttyUSB0 put Hass-Mqtt-Esp8266-Pins/src/hass_mqtt ampy -p /dev/ttyUSB0 put Hass-Mqtt-Esp8266-Pins/src/main.py
- Configure Wifi, MQTT and GPIO pin settings
screen /dev/ttyUSB0 115200
>>> import hass_mqtt.setup
… and let the interactive setup process guide you … - Restart the ESP8266 board
>>> from machine import reset; reset()
For more info, please see https://github.com/AlexMekkering/Hass-Mqtt-Esp8266-Pins and please let me know what you think about it.
