I have a python server running for my alarmsystem.
Everytime the server loses connection it is reconnecting by the way this is setup, i have to restart home assistant everytime when the connection was lost before the alarm zones are found again.
Logger: homeassistant.helpers.entity
Source: components/nx584/alarm_control_panel.py:135
First occurred: 03:02:30 (3 occurrences)
Last logged: 03:02:52
Update for alarm_control_panel.nx584 fails
File "/usr/src/homeassistant/homeassistant/helpers/entity.py", line 538, in async_update_ha_state
await self.async_device_update()
File "/usr/src/homeassistant/homeassistant/helpers/entity.py", line 744, in async_device_update
await task
File "/usr/local/lib/python3.10/concurrent/futures/thread.py", line 58, in run
File "/usr/src/homeassistant/homeassistant/components/nx584/alarm_control_panel.py", line 135, in update
if not part["armed"]:
UnboundLocalError: local variable 'part' referenced before assignment
I have the same issue. Only fix seems to be to restart HA. The ironic part is the NX584 server is still running and show that HA is still polling it, but somehow HA like gives up if connections are lost temporarily.
