I’m migrating from domoticz to Home Assistant.
Home Assistant picked up all my Z-Wave nodes from my aeotec Z-Stick. Unfortunately I forgot to merge the OZW config file for my Eurotronic Spirit Z Thermostats before the first start.
Now they all show up as “EUROtronic Unknown: type=0003, id=0001…” and are not functional. OZW is not picking up the updated files. Unfortunately I did quite a lot of configuration work for the new system already, which I do not want to loose. Thus I want to avoid setting up a plain system.
On the other hand, I don’t want to exclude and re- include the Thermostats, as I need to retain the domoticz installation until my Home Assistant config is finalized - including all necessary scripts.
Long question short:
Is there a way to re- learn the nodes without excluding? E.g. deleting a cache file? If yes, which files do I have to modify?
Thanks Dirk
