Hi everyone! If I ever switch to a new SkyConnect from my old SkyConnect, do I need to re-pair all connected devices? I know for a specific Sonoff-dongle, re-pairing isn’t needed. How about SkyConnect to SkyConnect?
Thank you.
Thank you.
Are you using ZHA or Z2M?
I have used both in the past. This is for a new project, so I’m happy to choose the one that doesn’t require re-pairing in the furure.
This applies to replacing any coordinator in Z2M https://www.zigbee2mqtt.io/guide/faq/#how-do-i-migrate-from-one-adapter-to-another as you are not changing the chipset you should be good to just copy the IEEE address from the old adapter to the new and update the serial port.
For ZHA see: Zigbee Home Automation - Home Assistant
