Hi, could I please have some advise to how to “read” / “see” values in esphome/homeassistant?
I have the PZEM platform showing V, A, Hz etc… correctly.
Now I have connected a real MODBUS RTU to my esphome and I off course get strange values every second. I would like to see the RAW serial data that gets received to see if I can translate that to sensors in HA.
The MODBUS values come from a solar inverter.
I really have googled any topic about modbus / esphome but it is VERY SCARS…
My config:
uart:
tx_pin: D1
rx_pin: D2
baud_rate: 9600
stop_bits: 1
And this give me CORRECT values when I use a real PZEM (of course):
- platform: pzemac
update_interval: 1s
current:
voltage:
power:
unit_of_measurement: W
icon: mdi:flash-outline
frequency:
power_factor:
energy:
Main question: How can I see the RAW serial data on pin D1 / D2?
I might then be able to use:
EDIT: I also have a hard time understanding how to use above link …
Currently with the MODBUS connected to pzem config I get totally weird values :-):
[14:41:56][D][pzemac:049]: PZEM AC: V=0.1 V, I=8716.288 A, P=216.9 W, E=6815744.0 Wh, F=87.1 Hz, PF=0.00
[14:41:56][V][sensor:013]: 'pzem016modbus V': Received new state 0.100000
[14:41:56][D][sensor:092]: 'pzem016modbus V': Sending state 0.10000 V with 1 decimals of accuracy
[14:41:56][V][sensor:013]: 'pzem016modbus A': Received new state 8716.288086
[14:41:56][D][sensor:092]: 'pzem016modbus A': Sending state 8716.28809 A with 3 decimals of accuracy
[14:41:56][V][sensor:013]: 'pzem016modbus W': Received new state 216.899994
[14:41:56][D][sensor:092]: 'pzem016modbus W': Sending state 216.89999 W with 1 decimals of accuracy
[14:41:56][V][sensor:013]: 'pzem016modbus - Dagverbruik': Received new state 2048.702393
[14:41:56][D][sensor:092]: 'pzem016modbus - Dagverbruik': Sending state 2.04870 kWh with 3 decimals of accuracy
[14:41:56][V][sensor:013]: 'pzem016modbus Wh': Received new state 6815744.000000
[14:41:56][D][sensor:092]: 'pzem016modbus Wh': Sending state 6815744.00000 Wh with 0 decimals of accuracy
[14:41:56][V][sensor:013]: 'pzem016modbus Hz': Received new state 87.099998
[14:41:56][D][sensor:092]: 'pzem016modbus Hz': Sending state 87.10000 hz with 1 decimals of accuracy
[14:41:56][V][sensor:013]: 'pzem016modbus Pf': Received new state 0.000000
[14:41:56][D][sensor:092]: 'pzem016modbus Pf': Sending state 0.00000 with 2 decimals of accuracy
[14:41:57][D][pzemac:049]: PZEM AC: V=0.1 V, I=8650.752 A, P=216.8 W, E=6684672.0 Wh, F=90.0 Hz, PF=0.00
[14:41:57][V][sensor:013]: 'pzem016modbus V': Received new state 0.100000
[14:41:57][D][sensor:092]: 'pzem016modbus V': Sending state 0.10000 V with 1 decimals of accuracy
[14:41:57][V][sensor:013]: 'pzem016modbus A': Received new state 8650.751953
[14:41:57][D][sensor:092]: 'pzem016modbus A': Sending state 8650.75195 A with 3 decimals of accuracy
[14:41:57][V][sensor:013]: 'pzem016modbus W': Received new state 216.800003
[14:41:57][D][sensor:092]: 'pzem016modbus W': Sending state 216.80000 W with 1 decimals of accuracy
[14:41:57][V][sensor:013]: 'pzem016modbus - Dagverbruik': Received new state 2048.762695
[14:41:57][D][sensor:092]: 'pzem016modbus - Dagverbruik': Sending state 2.04876 kWh with 3 decimals of accuracy
[14:41:57][V][sensor:013]: 'pzem016modbus Wh': Received new state 6684672.000000
[14:41:57][D][sensor:092]: 'pzem016modbus Wh': Sending state 6684672.00000 Wh with 0 decimals of accuracy
[14:41:57][V][sensor:013]: 'pzem016modbus Hz': Received new state 90.000000
[14:41:57][D][sensor:092]: 'pzem016modbus Hz': Sending state 90.00000 hz with 1 decimals of accuracy
[14:41:57][V][sensor:013]: 'pzem016modbus Pf': Received new state 0.000000
[14:41:57][D][sensor:092]: 'pzem016modbus Pf': Sending state 0.00000 with 2 decimals of accuracy
[14:41:58][D][pzemac:049]: PZEM AC: V=0.1 V, I=8650.752 A, P=219.8 W, E=6684672.0 Wh, F=90.5 Hz, PF=0.00
[14:41:58][V][sensor:013]: 'pzem016modbus V': Received new state 0.100000
[14:41:58][D][sensor:092]: 'pzem016modbus V': Sending state 0.10000 V with 1 decimals of accuracy
[14:41:58][V][sensor:013]: 'pzem016modbus A': Received new state 8650.751953
[14:41:58][D][sensor:092]: 'pzem016modbus A': Sending state 8650.75195 A with 3 decimals of accuracy
[14:41:58][V][sensor:013]: 'pzem016modbus W': Received new state 219.800003
[14:41:58][D][sensor:092]: 'pzem016modbus W': Sending state 219.80000 W with 1 decimals of accuracy
[14:41:58][V][sensor:013]: 'pzem016modbus - Dagverbruik': Received new state 2048.823730
[14:41:58][D][sensor:092]: 'pzem016modbus - Dagverbruik': Sending state 2.04882 kWh with 3 decimals of accuracy
[14:41:58][V][sensor:013]: 'pzem016modbus Wh': Received new state 6684672.000000
[14:41:58][D][sensor:092]: 'pzem016modbus Wh': Sending state 6684672.00000 Wh with 0 decimals of accuracy
[14:41:58][V][sensor:013]: 'pzem016modbus Hz': Received new state 90.500000
[14:41:58][D][sensor:092]: 'pzem016modbus Hz': Sending state 90.50000 hz with 1 decimals of accuracy
[14:41:58][V][sensor:013]: 'pzem016modbus Pf': Received new state 0.000000
[14:41:58][D][sensor:092]: 'pzem016modbus Pf': Sending state 0.00000 with 2 decimals of accuracy
[14:41:59][D][pzemac:049]: PZEM AC: V=0.1 V, I=8781.824 A, P=220.5 W, E=6750208.0 Wh, F=93.6 Hz, PF=0.00
[14:41:59][V][sensor:013]: 'pzem016modbus V': Received new state 0.100000
[14:41:59][D][sensor:092]: 'pzem016modbus V': Sending state 0.10000 V with 1 decimals of accuracy
[14:41:59][V][sensor:013]: 'pzem016modbus A': Received new state 8781.824219
[14:41:59][D][sensor:092]: 'pzem016modbus A': Sending state 8781.82422 A with 3 decimals of accuracy
[14:41:59][V][sensor:013]: 'pzem016modbus W': Received new state 220.500000
[14:41:59][D][sensor:092]: 'pzem016modbus W': Sending state 220.50000 W with 1 decimals of accuracy
