Has anyone tried this integration with a B5178? It is a dual indoor and outdoor thermometer and humidity sensor. It uses Bluetooth so I would think it would be similar but the packets might be a little different. Here is a link https://www.amazon.com/gp/product/B0872ZPQSJ to the one I purchased. It communicates over 433 between the base unit and the outdoor sensor but the communication to the phone is BLE.
For thirty bucks you can get 10 Xiaomi LYWSD03MMC units that you can have working in 30 minutes. Or 5 of them and a six pack of IPA s Only benny I can see of this unit is the 433 mhz, if you needed to have a sensor a long distance away. Assuming that the range of this 433 mhz device is good and better than you could get with a BLE device.
The reason I liked the B5178 is because it has an outdoor module that has no screen. It is just a module with a battery. Do you know how the Xiaomi LYWSD03MMC does outdoors?
I read through some of the Q&A section for the product on Amazon, you might want to do the same⦠vendors response on using it outside : āPlease protect it from the weather.ā
My Xiaomi has been outside 7x24 for six months inside two ziplock sandwich bags. If you want to go 1st class, get one of the mobile phone waterproof bags for a couple bucks.
Rain, hail wind and temps from 28F to 140F recorded so far (it is not completely shaded from sun). The biggest issue with all of these outdoor sensors is there humidity readings after rain. You end up with water all around the sensor until the sun evaporates it, so you end up with inaccurate humidity reading for a considerable period after rain or other significant moisture.
'Is the outdoor sensor waterproof? I want to place it outside in my garden area. Do I need to protect it from the weather in some way?
Answer:The outdoor sensor is not totally waterproof. Please protect it from the weather.
By Govee US SELLER on March 30, 2021'
OK. Thanks. I ordered some Xiaomi LYWSD03MMC as I found a outdoor wall mount for it on thingiverse that I can print. I bought a backup one in case it gets fried. I will take into account the humidity delay after a rain.
With the ziplocs how do you handle letting air in so it can measure humidity?
The bags are not really airtight. I could probably get more accurate reading if I just stuck the unit on the wall exposed. As long as you keep it out of direct moisture I think it will be fine. And again, for 4 bucksā¦
I didnāt see the H5102 details mentioned yet, so Iāll add the version of the ESP Home BLE tracker that worked for me on that version of the sensor. Should be the right version for H5101 or H5102, which is actually very close to the H5072/H5075, with the data location just off by a byte.
I am coming late to this discussion. I have read through the whole post. What I did not understand is where I should be putting this. I have H5075s downstairs and they do not reach my upstairs system. I have esphome and esp32 boards, just not sure what to do with the above.
the_badluck - If you have a functional esphome running, youād need to edit that esphome code, adding some sensor definitions and a corresponding āesp32_ble_trackerā section which defines how to get at the specific data values for those sensors. Maybe start with John.McDowellās example but swap in the H5075 specific section from mwildrick (adjusting the names of the locations and the MAC address to match your usage).
I have to say thanks for all those that contributed code here. I got a couple 5075s on Amazon and they were up and running in about 15 minutes thanks to all the code snippets here!
To add some more clarity - in the example above the 3E hex value (5th byte in manf. adv.) seems to change with temp and the B4 value (7 in manf. adv.) changes with humidity.
The problem is that whenever I convert these to integer it never relates to an accurate temp. or humidity. Iāve tried 2 pair and 3 pair values with divisors and modulus with what prior examples in this thread.
Iāve also looked at other examples which seem to point to a message payload that is 13 bytes long - none of the messages that broadcast when the verbose logging is enabled show thisā¦they are all 9 bytes for the manf. and 42 bytes for the service data.
Am I just missing something here? In the example posted above the temp should be around 20.1C and humidity would be around 35.5%ā¦
Is there a way to display the entire message payload with esp_ble_tracker? Iāve created lambdaās that convert x[?] to display each position but the decoding always gives a result (whether 16 bit or 8 bit) thatās not accurateā¦
More detail - hereās an example of a python decode:
def check_is_gvh5179(self) -> bool:
"""Check if mfg data is that of Govee H5179."""
return self._mfg_data_check(11, 6) and self._mfg_data_id_check("0188")
And the twos compliment:
def twos_complement(n: int, w: int = 16) -> int:
"""Two's complement integer conversion."""
# Adapted from: https://stackoverflow.com/a/33716541.
if n & (1 << (w - 1)):
n = n - (1 << w)
return n
This code is located here:
Can anyone interpret this and take a stab at a lambda that I could test?
Thanks guys I have 4 Govee 5075 working on this script that i put together from code posted in here⦠Here is mine that works⦠you can keep adding more as as needed see comments in code
esphome:
# Name Is From When you Setup The ESP32
esp32:
board: esp32dev
framework:
type: arduino
# GOVEE Sensor1 CHANGE NAMES AS NEEDED here and in Lamda Section
name: "govee1 Humidity"
unit_of_measurement: '%'
icon: "mdi:water-percent"
name: "govee1 Temperature"
unit_of_measurement: '° F'
icon: "mdi:thermometer"
icon: "mdi:battery"
# GOVEE Sensor2 CHANGE NAMES AS NEEDED here and in Lamda Section
name: "govee2 Humidity"
name: "govee2 Temperature"
icon: "mdi:battery"
# GOVEE Sensor3 CHANGE NAMES AS NEEDED here and in Lamda Section
name: "govee3 Humidity"
name: "govee3 Temperature"
icon: "mdi:battery"
# GOVEE Sensor4 CHANGE NAMES AS NEEDED here and in Lamda Section
name: "govee4 Humidity"
name: "govee4 Temperature"
icon: "mdi:battery"
# Enable logging
logger:
# Enable Home Assistant API
api:
# Your Over The Air Password
ota:
password: "861291xx35895xx43ea2xxxx80b12"
# Wifi login and Password
wifi:
ssid: !secret wifi_ssid
ap:
ssid: "Esp-Govee Fallback Hotspot"
password: "z3nfxBoGdDub"
# Script For The First 5075 Govee Themometer/Humidity Sensor
esp32_ble_tracker:
on_ble_advertise:
- mac_address: A4:C1:38:xx:xx:xx #MAC Adress of First Sensor
then:
- lambda: |-
for (auto data : x.get_manufacturer_datas()) {
if(data.data.size()==6) {
const int basenum = (int16_t(data.data[1]) << 16) + (int16_t(data.data[2]) << 8) + int16_t(data.data[3]);
const float temperature = ((basenum / 10000.0f)*9.0/5.0 + 32.0);
const float humidity = (basenum % 1000) / 10.0f;
const float battery_level = uint16_t(data.data[4]) / 1.0f;
int16_t rssi=x.get_rssi();
id(govee1_humidity).publish_state(humidity);
id(govee1_temperature).publish_state(temperature);
id(govee1_battery).publish_state(battery_level);
# Script For The Second 5075 Govee Themometer/Humidity Sensor
- mac_address: A4:C1:38:xx:xx:xx #MAC Adress of Second Sensor
then:
- lambda: |-
id(govee2_humidity).publish_state(humidity);
id(govee2_temperature).publish_state(temperature);
id(govee2_battery).publish_state(battery_level);
# Script For The Third 5075 Govee Themometer/Humidity Sensor
- mac_address: A4:C1:38:xx:xx:xx #MAC Adress of Third Sensor
then:
- lambda: |-
id(govee3_humidity).publish_state(humidity);
id(govee3_temperature).publish_state(temperature);
id(govee3_battery).publish_state(battery_level);
# Script For The Forth 5075 Govee Themometer/Humidity Sensor
- mac_address: A4:C1:38:xx:xx:xx #MAC Adress of Forth Sensor
then:
- lambda: |-
id(govee4_humidity).publish_state(humidity);
id(govee4_temperature).publish_state(temperature);
id(govee4_battery).publish_state(battery_level);
FYI
Here is my code for the Govee 5183 meat thermometer.
If the probe is not connected or the target temp is not set then I show a number to big to be right.
Also, currently, the only way to set the target temp is with the app.
Not sure how to send a BLE or what that message would look like.
I left some debug code.
esp32_ble_tracker:
on_ble_advertise:
- mac_address: A4:C1:xx:xx:xx:xx
then:
- lambda: |-
ESP_LOGD("ble_adv", "New BLE device");
ESP_LOGD("ble_adv", " address: %s", x.address_str().c_str());
ESP_LOGD("ble_adv", " name: %s", x.get_name().c_str());
ESP_LOGD("ble_adv", " Advertised service UUIDs:");
for (auto uuid : x.get_service_uuids()) {
ESP_LOGD("ble_adv", " - %s", uuid.to_string().c_str());
ESP_LOGD("ble_adv", " Advertised service data:");
for (auto data : x.get_service_datas()) {
ESP_LOGD("ble_adv", " - %s: (length %i)", data.uuid.to_string().c_str(), data.data.size());
ESP_LOGD("ble_adv", " Advertised manufacturer data:");
if (data.data.size() == 14){
for (int i=0;i<14;i++){
ESP_LOGD("ble_adv", "-%i", data.data[i]);
if (data.data[8] == 255 && data.data[9] == 255){
id(meat_tempture).publish_state(99999999.00);
} else{
int temp_lsb = (data.data[8] * 256) + data.data[9];
float temperature = float(temp_lsb)/100*9.0/5.0 + 32.0;
id(meat_tempture).publish_state(temperature);
if (data.data[10] == 255 && data.data[11] == 255){
id(meat_taget_tempture).publish_state(99999999.00);
} else{
int temp_lsb = (data.data[10] * 256) + data.data[11];
id(meat_taget_tempture).publish_state(temperature);
name: "Meat Tempture"
name: "Meat Traget Tempture"
