I want to have a read only boolean indicator which has a state and is being set by an MQTT device i built to track in grafana. i am currently using a switch, which is the closest thing i found, but i don’t need the “command_topic” as it is readonly so i just put NULL string there - is there any suggested alternative to this?
switch:
- platform: mqtt
name: 'Lamp Awake Mode State'
state_topic: "home/lamp/awake"
command_topic: "NULL"
payload_on: '1'
payload_off: '0'
i thought about “input_boolean” but it does not the set state feature for incoming payload which is what i need.
