Read sensor state
I defined a sensor and I’m simply trying to work with the sensor value. But whenever I try to read it it’s unknown or not existing.
    sensors:
      woonkamer_target_temp_diff:
        value_template: >-
          {% set current_temp = states.climate.woonkamer.attributes.current_temperature|int %}
          {% set target_temp  = states.climate.woonkamer.attributes.temperature|int %}
          {{ (target_temp - current_temp)|int }}
sBKoaLb0DC
The state is -2.
Now how do I display or use this in a template?
{{ states.sensor.sensor.woonkamer_target_temp.state }}
UndefinedError: ‘None’ has no attribute ‘woonkamer_target_temp’
{{states('sensor.woonkamer_target_temp')}}
unknown
Trying all variants Google will come up with still give invalid results.
Have you checked the entity_id in the Devtools?
I would asume the sensor is called “sensor.woonkamer_target_temp_diff”.
{{states('sensor.woonkamer_target_temp_diff')}}
I’m an idiot, not sure how I missed this.
There is a typo in
sensor is double, should be {{ states.sensor.woonkamer_target_temp.state }}
and @dennis84de has a point that you might be looking for sensor.woonkamer_target_temp_diff
You can try them out in Templates of Developer tools.
And you sure you want to use |int and not |float ?
