I’ve got a few TP-Link HS110’s switching a couple of lamps around the house, and for they work very well, I have nutted out time offsets using the sunrise/sunset for the kids nightlights, etc.
The issue I have is that I’m finding that for some reason, Hassbian needs a reboot most days and if I’ve missed this before I go to work and the kids nightlights are on while the Pi is requiring a reboot that Home Assistant isn’t reading the state if it’s missed the trigger time.
My YAML code for one of the switches is as below
- alias: Night Light On
initial_state: True
hide_entity: True
platform: sun
event: sunset
offset: '-00:45:00'
service: homeassistant.turn_on
entity_id: switch.night_light
- alias: Night Light Off
platform: sun
event: sunrise
offset: '-00:45:00'
service: homeassistant.turn_off
Hoping someone can point me in the right direction - I’ve done some searching, and unable to find how to sort it out…
thanks @sjee - the issue I have is that if the Pi freezes (I think it’s a memory leak, but can’t prove it yet), and misses the automation trigger, I have a set of lights that either don’t turn on, or don’t turn off.
e.g. today, the Pi locked up sometime around 5am, so it didn’t turn off the kids’ night lights, as sunrise was around 7:15, so the automation would normally have turned off the lights at approx 6:30 …
Maybe my question is “how do I ensure a missed automation runs after Hassbian is restarted”
You can add a trigger for HA starting to your automations. I do this for a lot of my automations. Something like this:
initial_state: True
hide_entity: True
- platform: sun
event: sunset
offset: '-00:45:00'
- platform: homeassistant
event: start
condition:
condition: or
conditions:
- condition: sun
after: sunset
after_offset: '-00:45:00'
- condition: sun
before: sunrise
before_offset: '-00:45:00'
service: switch.turn_on
- platform: sun
event: sunrise
offset: '-00:45:00'
event: start
condition:
- condition: sun
after: sunrise
- condition: sun
before: sunset
service: switch.turn_off
These automations will trigger either at the desired time relative to sunrise or sunset, or they will trigger when HA starts. For the latter the conditions will make sure the correct actions run depending on the time of day relative to sunrise and sunset.
BTW, if you’re turning a switch on or off then it’s better to use the switch.turn_off and switch.turn_on services. You can use the homeassistant.turn_off and homeassistant.turn_on services, but they will just turn around and call the switch services, so you might was well just use the switch services directly (since you’re only controlling a switch. If you were turning switches, lights, etc on or off at the same time, then the homeassistant services are the right ones to use.)
can someone help me regarding the condition function - what have I got wrong here for getting it to turn on/off a light based on time if HASS is restarted?
- alias: Living Room Lamp Off
- platform: time
at: '22:15:00'
event: start
condition:
- condition: time
after: '22:15:00'
- service: switch.turn_off
entity_id: switch.upstairs_living_room
I’ve also tried this to no avail:
- platform: time
at: '22:15:00'
event: start
condition:
- condition: state
state: 'on'
- condition: time
after: '22:15:00'
You shouldn’t need to add the condition for the switch being off, although that shouldn’t hurt. In general it looks ok. The only thing I can think of is if the switch platform isn’t ready when the homeassistant_start event is fired. That’s possible. In which case you may need to add a delay, which, BTW, is what I do:
Also note that the condition you wrote means between 22:15:00 and midnight. The action will not run after midnight. If you want it to run up to some time in the morning, then you’ll need to add a before: parameter to the condition.
That shouldn’t be necessary either. I have automations just like this (i.e., trigger at a particular time and check that it’s after that exact same time in the condition.) Also the OP, although not stated explicitly, implies the problem is not with the time trigger, but with the homeassistant start event.
thanks again @pnbruckner … I completely missed the 22:15 - 23:59:59 issue, with the multiple conditions.
I’ll give this a shot tonight - I think that should catch the issue of after midnight by ensuring it will turn off before sunrise and/or sunset? To me it doesn’t look quite elegant enough, but if it works…
- platform: time
at: '22:15:00'
event: start
condition:
- condition: time
after: '22:15:00'
- condition: sun
before: sunrise
- condition: sun
before: sunset
Conditions are and’d, so what you wrote means the light will only turned off it it’s between 22:15 and midnight, AND before sunrise, AND before sunset. Hmm, I don’t think that will ever be true.
What time period do you want the light to turn off if HA restarts? Let’s say you want between 22:15 and sunrise the next morning. Then you’d want this:
- platform: time
at: '22:15:00'
event: start
condition:
condition: or
conditions:
- condition: time
after: '22:15:00'
- condition: sun
before: sunrise
So now the condition is between 22:15 and midnight, OR between midnight and sunrise.
the turn on condition is 15 minutes after sunset, and in the event HA has to restart during the on or the off cycle, or for some reason it hangs (like yesterday), I’m just trying to ensure the state is as expected when it restarts…
