Either you use a trigger state node. This will fire each time you change the slider.
Or a current state node, this will only check the number in the sequence and need a different “trigger”.
[{"id":"3877cd37.bf6712","type":"trigger-state","z":"caebef34.4abf3","name":"","server":"4bbca37b.1700ec","exposeToHomeAssistant":false,"haConfig":[{"property":"name","value":""},{"property":"icon","value":""}],"entityid":"input_number.google_say_volume","entityidfiltertype":"exact","debugenabled":false,"constraints":[],"constraintsmustmatch":"all","outputs":2,"customoutputs":[],"outputinitially":false,"state_type":"str","x":420,"y":520,"wires":[["69514772.9a8108"],[]]},{"id":"69514772.9a8108","type":"debug","z":"caebef34.4abf3","name":"","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"true","targetType":"full","statusVal":"","statusType":"auto","x":720,"y":560,"wires":[]},{"id":"257306f9.d18dba","type":"inject","z":"caebef34.4abf3","name":"","props":[{"p":"payload"},{"p":"topic","vt":"str"}],"repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"","payload":"","payloadType":"date","x":150,"y":640,"wires":[["df9ed939.632068"]]},{"id":"df9ed939.632068","type":"api-current-state","z":"caebef34.4abf3","name":"","server":"4bbca37b.1700ec","version":1,"outputs":1,"halt_if":"","halt_if_type":"str","halt_if_compare":"is","override_topic":false,"entity_id":"input_number.google_say_volume","state_type":"str","state_location":"payload","override_payload":"msg","entity_location":"data","override_data":"msg","blockInputOverrides":false,"x":420,"y":640,"wires":[["69514772.9a8108"]]},{"id":"4bbca37b.1700ec","type":"server","name":"Home Assistant","legacy":false,"addon":true,"rejectUnauthorizedCerts":true,"ha_boolean":"y|yes|true|on|home|open","connectionDelay":true,"cacheJson":true}]
