Read value from text file?
I need to create a sensor by reading a value from this text file:
Array
    [temp] => 26.7ºC
    [local_time] => 08:06
    [lightStat] => Array
I need the sensor to return the “26.7” value. The Scrape sensor seems to only be able to find text in a web page. Anyone can guide me in the right direction as to how to do this? Thanks!
Instead of http://example.com you could try the scrape editor with file://path/to/your_file.txt
Not sure if this will work, but worth a shot.
Otherwise use the Command Line Sensor with awk/sed/grep to capture the value from the file with regex.
Home Assistant has the File Sensor integration but it’s designed to read JSON-formatted data from a file. Because your data has a custom format, you’ll need to use Skye’s suggestion (Command Line Sensor).
Thanks, I’ve modified the output to be in json format and the File Sensor works perfectly.
