Can someone please help me how to read this value with Scrape ?
I suggest you don’t use that page, but rather this one:
This ensures that it’s value is always in same HTML XPath location. In the table you link to, it can vary.
so if I’m not mistaken (and it accepts XPath) Otherwise you need CSS selector (there are browser addons to help youu pick the right value).
- platform: scrape
resource: https://2cryptocalc.com/eth-mining-calculator?hashrate=299
select: "//*[@id="pool24coins"]/text()"
Obviously change hashrate to the hashrate your rig mines
Oh yes thats correct. thx
But sadly this code doesn´t work for me.
Unfortunately, I don’t really know my way around this.
Maybe someone can tell me which parameters work here.
Wrong quotations lol. Try this
- platform: scrape
select: '//*[@id="pool24coins"]/text()'
Unfortunately, I just can’t get it to run.
This is what the code looks like for me now.
But unfortunately no entity is created.
You should make it a sensor?
Example configuration.yaml entry
- platform: scrape
resource: https://www.home-assistant.io
select: ".current-version h1"
So it would look like:
- platform: scrape
It is a Sensor. My configuration.yaml looks like this:
Did you try it? Is it working with your installation of hass?
look like pointing to the right place
so the select needs looking at
you need to do some more reading.
Hey, I just launched a custom integration that lets you extract values from HTTP with XPath.
Feel free to check it out here: GitHub - mauro-midolo/homeassistant_xpath_scraper: Home Assistant XPath Scraper is an integration that enables HTTP scraping using XPath expressions.
