I’m trying to read the data from a modbus (RS485) power meter YTL DTS353F2. Whatever config I’ve tried, no success.
I’m using the same hardware as the esphome documentation (Modbus Controller — ESPHome)
Register matrix can be found here: https://www.elektramat.nl/media/wysiwyg/Specsheet/Modbus_register_matrix.pdf
modbus:
uart_id: uart_modbus
uart:
- tx_pin: GPIO17
rx_pin: GPIO16
baud_rate: 9600
#parity: even
data_bits: 8
stop_bits: 1
debug:
modbus_controller:
- id: modbus1_01
address: 0x0001 # the Modbus device addr
modbus_id: modbus1
update_interval: 5s
- platform: modbus_controller
modbus_controller_id: modbus1_01
name: "Laadpaal L1 Voltage"
register_type: holding
address: 0x000E
unit_of_measurement: "V"
value_type: U_WORD
Result is
[10:14:45][D][uart_debug:114]: >>> 01:03:00:0E:00:01:E5:C9
[10:14:45][W][modbus:096]: Modbus CRC Check failed! F020!=0E
[10:14:45][D][uart_debug:114]: <<< 01:03:00:0E:00:01:E5:C9
[10:14:45][D][modbus_controller:034]: Modbus command to device=1 register=0x0E countdown=0 removed from queue after send
Parity: even
Baud_rate: 1200
And/or:
value_type: FP32
Thanks for your reply. Tested it buy no difference.
Even with the AB wires disconnected, I see this result.
What could cause this echo?
RX/TX were crossed.
From ESP to RS485 board, RX => RX and TX => TX is the right way. On RS485 board, TX light and RX light should not light up at the same time (then rx/tx are crossed).
Now it’s working:
modbus:
uart:
- tx_pin: GPIO17
rx_pin: GPIO16
baud_rate: 9600
parity: even
data_bits: 8
stop_bits: 1
modbus_controller:
- id: modbus1_01
modbus_id: modbus1
update_interval: 10s
setup_priority: -10
address: 0x000E
value_type: FP32
accuracy_decimals: 1
name: "Laadpaal L2 Voltage"
address: 0x0010
value_type: FP32
name: "Laadpaal L3 Voltage"
address: 0x0012
value_type: FP32
name: "Laadpaal Grid Frequency"
address: 0x0014
unit_of_measurement: "Hz"
value_type: FP32
accuracy_decimals: 3
name: "Laadpaal L1 Current"
address: 0x0016
unit_of_measurement: "A"
value_type: FP32
name: "Laadpaal L2 Current"
address: 0x0018
value_type: FP32
name: "Laadpaal L3 Current"
address: 0x001A
value_type: FP32
name: "Laadpaal Total Active Power"
address: 0x001C
unit_of_measurement: "kW"
value_type: FP32
name: "Laadpaal L1 Active Power"
address: 0x001E
value_type: FP32
name: "Laadpaal L2 Active Power"
address: 0x0020
value_type: FP32
name: "Laadpaal L3 Active Power"
address: 0x0022
value_type: FP32
name: "Laadpaal Energy Consumed"
address: 0x0100
unit_of_measurement: "kWh"
value_type: FP32
state_class: total_increasing
device_class: energy
