I have a DirectLogic 205/H2-ECOM100 with a Green, Blue, Orange, Red & Sound light tower for alarms. I wish to just read the status of the light tower. As the conditions of the light tower changes, HA reports all lights are off with no status changes.
It must be something right in front of me but I just can’t see it.
Here is my code.
modbus:
- name: hub1
type: tcp
host: 192.168.xxx.yyy
port: 502
binary_sensors:
- name: "Status Green"
device_class: light
address: 2058 # for Y11 output coil
- name: "Status Blue"
device_class: light
address: 2059 # for Y12 output coil
- name: "Status Orange"
device_class: light
address: 2060 # for Y13 output coil
- name: "Status Red"
device_class: light
address: 2061 # for Y14 output coil
- name: "Status Alarm Sound"
device_class: problem
address: 2062 # for Y15 output coil
Did you need to specify a slave address?
I’m really not sure about why I need the “slave”, but with or without I’m not seeing the current correct value in the history log.
But I did see better responses when my DL205 communicated with my DL05 early this morning. So it may be my H2-ECOM100.
As an experiment, I set up a peer to peer with the ECOM100 to my HA IP . Also I increased the scan interval time to 2 seconds and added slave: 255. No change but I’ll let it run for a few hours to see if there is any pattern I can detect.
So now my code is
modbus:
- name: hub1
type: tcp
port: 502
binary_sensors:
device_class: light
address: 2058
scan_interval: 2
slave: 255
device_class: light
address: 2059
scan_interval: 2
slave: 255
device_class: light
address: 2060
scan_interval: 2
slave: 255
device_class: light
address: 2061
scan_interval: 2
slave: 255
address: 2062
scan_interval: 2
slave: 255
Turns out it was a wrong register number error on my part. I read the instructions given by Automation Direct. There is even a Excel Spreadsheet that can, supposedly, help determine the correct Modbus register number. But it was off my 1.
So here is my code… that’s working ![:grinning: :grinning:](https://community.home-assistant.io/images/emoji/twitter/grinning.png?v=9)
modbus:
- name: hub1
type: tcp
port: 502
delay: 5
timeout: 5
binary_sensors:
device_class: light
address: 2057 # for Y11 output coil
scan_interval: 20
slave: 255
device_class: light
address: 2058 # for Y12 output coil
scan_interval: 20
slave: 255
device_class: light
address: 2059 # for Y13 output coil
scan_interval: 20
slave: 255
device_class: light
address: 2060 # for Y14 output coil
scan_interval: 20
slave: 255
address: 2061 # for Y15 output coil
scan_interval: 20
slave: 255
I’ll eventually clean it up but for now, I’m good and out.
