Hello all, I am trying to figure out how to implement a new set of hardware - the end goal is to get 1-second (or half-second!) resolution power data from a CT current sensor (induction sensor).
I know two good ways to get the data off the sensor:
1- use an Arduino to read the analog data
2- use an Enviro PHAT to read the analog data
The problem is how to get that data into Home Assistant.
1-The Ardunio has a library that will output a variable (Irms) - but I don’t know how to load that into Home Assitant.
2-I can easily read the analog data from the PHAT - but how do I go about calculating the RMS level? Sampling of the analog data needs to be a minimum of 144 Hz (60 Hz power times 2.4 for anti-aliasing). Once I’ve got all of those values, how do I get HA to run the calculation?
If anyone can guide me to some information / examples of either solution it would be greatly appreciated thanks!
I have built a sensor to monitor my pump status using SCT-013-030 with OpenMQTTGateway
I have modified their ADC sensor to include the EmonLib
Here is the relevant file
OpenMQTTGateway Addon - ESP8266 or Arduino program for home automation
Act as a wifi or ethernet gateway between your 433mhz/infrared IR signal and a MQTT broker
Send and receiving command by MQTT
Analog pin reading Addon
Copyright: (c)Florian ROBERT
Contributors:
- 1technophile
This file is part of OpenMQTTGateway.
OpenMQTTGateway is free software: you can redistribute it and/or modify
it under the terms of the GNU General Public License as published by
the Free Software Foundation, either version 3 of the License, or
(at your option) any later version.
OpenMQTTGateway is distributed in the hope that it will be useful,
but WITHOUT ANY WARRANTY; without even the implied warranty of
MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the
GNU General Public License for more details.
You should have received a copy of the GNU General Public License
along with this program. If not, see <http://www.gnu.org/licenses/>.
updated to check for 200 w threshold and update only every minute
#ifdef ZsensorADC
#include "EmonLib.h"
//#ifdef ESP8266
// ADC_MODE(ADC_TOUT);
//#endif
EnergyMonitor emon1;
//Time used to wait for an interval before resending adc value
unsigned long timeadc = 0;
void setupADC() {
emon1.current(A0, 111.1);
void MeasureADC(){
if (millis() > (timeadc + TimeBetweenReadingADC)) {//retriving value of temperature and humidity of the box from DHT every xUL
timeadc = millis();
static int persistedadc;
// trc(F("Checking analog value"));
double val = emon1.calcIrms(1480); // Calculate Irms only
// Serial.print(val*230.0); // Apparent power
// Serial.print(" ");
// Serial.println(val);
double power = val*230.0;
if (power < 200){
power = 0;
if (isnan(power)) {
trc(F("Failed to read from ADC !"));
}else{
if(power >= persistedadc + ThresholdReadingADC || power <= persistedadc - ThresholdReadingADC){
char val[10];
dtostrf(power,4,2,val);
//sprintf(value, "%d", power);
trc(F("Sending analog value to MQTT"));
trc(String(power));
client.publish(ADC,val);
persistedadc = power;
#endi
If you need the full configuration and files let me know.
