Tested before the Hass in a container solution … but for different parts of hardware I have build the HASS native on the Raspberry PI.
I could read the CPU temperature in the first situation (container solution) but not anymore in the ‘native linux’ install.
And the result is very fine … the HASS software is up and running.
The first thing I always do is to make the small script to see how ‘hot’ the CPU will be.
I used the samll configuration script like:
CPU temperature
platform: command_line
name: CPU Temperature
command: “cat /sys/class/thermal/thermal_zone0/temp”
unit_of_measurement: “°C”
value_template: “{{ (value | multiply(0.001)) | round(1) }}”
But always what I try to fix … the end result is ‘unkown’ temperature in the webscreen of HASS.
Dit anyone see this also before ?
I think something it will be about user rights, hidden python script or what else …
I will check the log files … may be I will see more information why this script will not show the correct temperature …
Note: tested this in the CLI-Shell … everything works fine.
Thanks for reply … in the log it shows me:
Command failed: cat /sys/class/thermal/thermal_zone0/temp
3:23 PM components/command_line/sensor.py (ERROR)
Looking on the systeem … no sensor.py ??
The other error is:
2019-11-15 14:23:00 ERROR (SyncWorker_5) [homeassistant.components.command_line.sensor] Command failed: cat /sys/class/thermal/thermal_zone0/temp
The command action failed … not the next line … ( I changed correct, thanks) … it seems that the native HASS needs an area same as ‘sudo shell’ … it don’t understand the commands given from the virtual HASS system …
I can not find the sensor.py file on the rpi … do you know how to find the file sensor.py ?
Something was wrong with the rights in the folder:
/home/homeassistant/.homeassistant/.storage/
I found this because the ‘auto start’ file ‘[email protected]’ was not activated anymore.
And their where a few files who are changed with user rights to root … but that must be homeassistant ( the default user ).
Now I see the temperature and other things in correct order.
Thanks for your replies …
