While there is an integration for Solax devices, it only works with the newer devices with a reverse proxy.
As a (hopefully) temporary solution, I read the data from the SolaX cloud service. The service returns a JSON which is too long to be stored as a sensor state (longer than 255…). To read different values from the JSON, my solution is to query the API multiple times, reading a different value from the JSON each time.
- platform: rest
resource: https://www.solaxcloud.com:9443/proxy/api/getRealtimeInfo.do?tokenId=MYAPITOKEN&sn=MYSN
method: GET
scan_interval: 60
value_template: "{{ value_json['result']['acpower'] | float }}"
unit_of_measurement: W
- platform: rest
method: GET
scan_interval: 300
value_template: "{{ value_json['result']['yieldtoday'] | float }}"
unit_of_measurement: kWh
- platform: rest
method: GET
scan_interval: 3600
value_template: "{{ value_json['result']['yieldtotal'] | float }}"
According to their documentation, you are not allowed to query the API too often, but in my experience so far, the API updates only every 5 minutes or so anyway.
The API provides additional values:
item / Description / Accuracy / Unit
inverterSN Unique identifier of inverter (Serial No. of inverter) - -
sn Unique identifier of communication module (Registration No.) - -
acpower Inverter.AC.power.total 1 W
yieldtoday Inverter.AC.energy.out.daily 0.1 KWh
yieldtotal Inverter.AC.energy.out.total 0.1 KWh
feedinpower Grid.power.total1 W
feedinenergy Grid.energy.toGrid.total 0.01 KWh
consumeenergy Grid.energy.fromGrid.total 0.01 KWh
feedinpowerM2 Inverter.Meter2.AC.power.total 1 W
soc BMS.energy.SOC 1 %
peps1 Inverter.AC.EPS.power.R 1 W
peps2 Inverter.AC.EPS.power.S 1 W
peps3 Inverter.AC.EPS.power.T 1 W
inverterType Inverter type, details refer to Table 4 in appendix - -
inverterStatus Inverter status, details refer to Table 5 in appendix - -
uploadTime Update time(2016-10-26 17:33:01) -
batPower Inverter.DC.Battery.power.total 1 W
powerdc1 Inverter.DC.PV.power.MPPT1 1 W
powerdc2 Inverter.DC.PV.power.MPPT2 1 W
