I’m developing a small plugin that lets me read some data from a file I mount inside my docker container.
In the plugin I basically just do:
fs.readFileSync('/etc/files/fileIwant', 'utf-8'))
And I’ve tried many different variations, using __dirname, absolute paths, relative ones etc. And yet I still only get an error similar to:
cannot read file from /data/node_modules/etc/files/fileIWant
I’m using the default node-red docker image.
I’m very confused what is going on and why I cannot read files from the /etc/files folder.
Is there something with node-red that is makes it so I cannot read from outside of the node_modules folder? Is it because of docker? I can see the files are in etc/files so it’s not like they aren’t there.
That’s what Docker does - it separates the container from the host system. So while there will be a “/etc” folder, it’s often not mapped to the same folder on the host - and this is the case with Node Red. You would have to place the file in a folder that the Node Red container can see, as listed below. For example if you store a file in “/mnt/data/supervisor/share” on the host, it will appear in “/share” to Node Red.
Host/volume
Path in container
/mnt/data/supervisor/addons/data/a0d7b954_nodered
/data
/mnt/data/supervisor/homeassistant
/config
/mnt/data/supervisor/ssl
/ssl
/share
/mnt/data/supervisor/media
/media
/dev
/dev
As you can see, “/etc” is not mapped and so it will only be visible inside the container.
