Hi, I am totally new to HA. I have been trying to read my solar data from a file and put into a dashboard Sensor Card so it is graphed.
I have a new installation of HA with only HACS added.
The following is the format in a solar log file which is updated every 5 mins with a bash script:
2021-04-02,15:30,3.4,2.1,337.8,357.1,1150,771,1852,20.5,15668.4,42,7.6,246.2,49.99,2
Date,Time,Amp PV1,Amp PV2,V PV1, V PV2, W PV1, W PV2, kW today, kW total,…
I can modify the data to any format if HA cant read a coma delimited file.
As a test (and after reading for hours getting started, help and forum post) I have been trying to get just basic info onto a sensor card without success.
In configuration.yaml I have:
- platform: file
file_path: /config/externaldata/temp.txt
value_template: '{{ value_json.temperature }}'
unit_of_measurement: "°C"
In /config/externaldata/temp.txt it have:
{"temperature": 21, "humidity": 39}
{"temperature": 22, "humidity": 36}
I have added a sensor card on the dashboard but I cant find how to associate the data with a card - how to get the card to display the data - there is no errors in the log file.
If I can just get the temp card to work the solar stuff should be reasonably easy - hopefully.
Any help would be most welcome.
