I am newbie to ESP Home, did some leds and plugs only and decided to develop my own device tracker. My ultimate objective is to have a battery powered tracker in my ebike with accelerometer, alarm, CAN interface to switch off/on engine, temperature sensors and more. However, I am stuck at the very beginning.
I bought ESP32-S3 A7670E 4G Development Board from waveshare because it has a lot of stuff on board directly and struggle with the very first task: to read the GNSS over UART.
I admit to try some AI LLM models for consultation, they never provide clear working code, however, some experiments narrowing down my problem pointed me to a suspicion that I do not receive any NMEA messages. UART sends AT commands somewhere but the board never responds. Therefore, I would like to begin with debugging of the problem.
I have verbose logging, so the log is quite long, but the important part would be the following:
[20:53:03][V][sensor:043]: āLongitudeā: Received new state -1.000000
[20:53:03][D][sensor:094]: āLongitudeā: Sending state -1.00000 Ā° with 6 decimals of accuracy
[20:53:03][VV][api.service:140]: send_sensor_state_response: SensorStateResponse {
key: 2355190616
state: -1
missing_state: NO
Interestingly, if I switch the GPIO pins RX<>TX, I get the same.
Just thinking whether the hardware is correctly assembled? Waveshare provide zero docs, but I guess that I should have the antenna connected and ensure the hardware switch is on. Thatās it.
I created a sensor for the ID ādesk_heightā in your code and it returns āunknownā in home assistant. Or what was your point, where should I see the debug log from the code?
ok then, thanks for your time. I need just a code that would work on my tiny case of reading GNSS over UART. The result -1 means, no NMEA message is sent. So I added switching on of the GNSS to the on_boot section, but no result. If you can help me instead of tell me that I need to be on a different level, I would appreciate it. I am novice in ESP Home but this seems to be super easy configuration, which does not work.
So first step I think is to see if you can recieve some UART messages and see them in the ESPHome logs. Try this. You may need to adjust the baud_rate and/or maybe the after:
I created a lot of buttons sending AT commands I found in the documentation of A76xx
I properly configured the UART according to the documentation of ESP32-S3
When I send the AT command, I get echo, which probably means the device received my command and sent it back - uart is properly configured, however, the device does not respond on any command as expected (OK, GPS data etcā¦) or in case of device reset, it certainly does not reset itself.
GPS is receiving -1 on everything, I am not sure how it is written in ESP home but it seems to me that it is independent on UART because the number is received under any uart configurations when I was switching pins etc.
I did not figure out where the debug log should be found. I am looking to the log after compilation but there is no change after adding the code from the section ādebugā of the āuart busā page on ESP Home documentation. Should I look elsewhere?
Here is my current log:
INFO ESPHome 2024.12.4
INFO Reading configuration /config/esphome/cannondale-tracker.yaml...
WARNING GPIO3 is a strapping PIN and should only be used for I/O with care.
Attaching external pullup/down resistors to strapping pins can cause unexpected failures.
See https://esphome.io/guides/faq.html#why-am-i-getting-a-warning-about-strapping-pins
INFO Generating C++ source...
INFO Compiling app...
Processing cannondale-tracker (board: esp32-s3-devkitc-1; framework: arduino; platform: platformio/[email protected])
HARDWARE: ESP32S3 240MHz, 320KB RAM, 8MB Flash
- toolchain-riscv32-esp @ 8.4.0+2021r2-patch5
- toolchain-xtensa-esp32s3 @ 8.4.0+2021r2-patch5
Dependency Graph
|-- AsyncTCP-esphome @ 2.1.4
|-- WiFi @ 2.0.0
|-- FS @ 2.0.0
|-- Update @ 2.0.0
|-- ESPAsyncWebServer-esphome @ 3.2.2
|-- DNSServer @ 2.0.0
|-- ESPmDNS @ 2.0.0
|-- noise-c @ 0.1.6
|-- Wire @ 2.0.0
|-- TinyGPSPlus @ 1.0.2
Compiling .pioenvs/cannondale-tracker/src/main.cpp.o
Linking .pioenvs/cannondale-tracker/firmware.elf
RAM: [= ] 12.6% (used 41360 bytes from 327680 bytes)
Flash: [===== ] 48.8% (used 896061 bytes from 1835008 bytes)
Building .pioenvs/cannondale-tracker/firmware.bin
Creating esp32s3 image...
Successfully created esp32s3 image.
esp32_create_combined_bin([".pioenvs/cannondale-tracker/firmware.bin"], [".pioenvs/cannondale-tracker/firmware.elf"])
Wrote 0xeadc0 bytes to file /data/build/cannondale-tracker/.pioenvs/cannondale-tracker/firmware.factory.bin, ready to flash to offset 0x0
esp32_copy_ota_bin([".pioenvs/cannondale-tracker/firmware.bin"], [".pioenvs/cannondale-tracker/firmware.elf"])
========================= [SUCCESS] Took 28.35 seconds =========================
INFO Successfully compiled program.
INFO Connecting to 192.168.2.185 port 3232...
INFO Connected to 192.168.2.185
INFO Uploading /data/build/cannondale-tracker/.pioenvs/cannondale-tracker/firmware.bin (896448 bytes)
Uploading: [============================================================] 100% Done...
INFO Upload took 8.66 seconds, waiting for result...
INFO OTA successful
INFO Successfully uploaded program.
INFO Starting log output from 192.168.2.185 using esphome API
INFO Successfully connected to cannondale-tracker @ 192.168.2.185 in 7.390s
INFO Successful handshake with cannondale-tracker @ 192.168.2.185 in 0.068s
[13:14:48][I][app:100]: ESPHome version 2024.12.4 compiled on Jan 21 2025, 13:14:07
[13:14:48][C][wifi:600]: WiFi:
[13:14:48][C][wifi:428]: Local MAC: 18:8B:0E:CD:4D:48
[13:14:48][C][wifi:433]: SSID: [redacted]
[13:14:48][C][wifi:436]: IP Address: 192.168.2.185
[13:14:48][C][wifi:440]: BSSID: [redacted]
[13:14:48][C][wifi:441]: Hostname: 'cannondale-tracker'
[13:14:48][C][wifi:443]: Signal strength: -71 dB āāāā
[13:14:48][C][wifi:447]: Channel: 4
[13:14:48][C][wifi:448]: Subnet: 255.255.255.0
[13:14:48][C][wifi:449]: Gateway: 192.168.2.1
[13:14:48][C][wifi:450]: DNS1: 192.168.2.131
[13:14:48][C][wifi:451]: DNS2: 192.168.2.1
[13:14:48][C][logger:185]: Logger:
[13:14:48][C][logger:186]: Level: DEBUG
[13:14:48][C][logger:188]: Log Baud Rate: 115200
[13:14:48][C][logger:189]: Hardware UART: USB_CDC
[13:14:48][C][i2c.arduino:071]: I2C Bus:
[13:14:48][C][i2c.arduino:072]: SDA Pin: GPIO3
[13:14:48][C][i2c.arduino:073]: SCL Pin: GPIO2
[13:14:48][C][i2c.arduino:074]: Frequency: 50000 Hz
[13:14:48][C][i2c.arduino:086]: Recovery: bus successfully recovered
[13:14:48][I][i2c.arduino:096]: Results from i2c bus scan:
[13:14:48][I][i2c.arduino:102]: Found i2c device at address 0x36
[13:14:48][C][uart.arduino_esp32:151]: UART Bus 0:
[13:14:48][C][uart.arduino_esp32:152]: TX Pin: GPIO18
[13:14:48][C][uart.arduino_esp32:153]: RX Pin: GPIO17
[13:14:48][C][uart.arduino_esp32:155]: RX Buffer Size: 256
[13:14:48][C][uart.arduino_esp32:157]: Baud Rate: 115200 baud
[13:14:48][C][uart.arduino_esp32:158]: Data Bits: 8
[13:14:48][C][uart.arduino_esp32:159]: Parity: NONE
[13:14:48][C][uart.arduino_esp32:160]: Stop bits: 1
[13:14:48][C][max17048:033]: MAX17048:
[13:14:48][C][max17048:034]: Address: 0x36
[13:14:48][C][max17048:035]: Voltage (V) 'Battery voltage'
[13:14:48][C][max17048:035]: Device Class: 'battery'
[13:14:48][C][max17048:035]: State Class: 'measurement'
[13:14:48][C][max17048:035]: Unit of Measurement: 'V'
[13:14:48][C][max17048:035]: Accuracy Decimals: 3
[13:14:48][C][max17048:036]: State of Charge (%) 'Battery level'
[13:14:48][C][max17048:036]: Device Class: 'battery'
[13:14:48][C][max17048:036]: State Class: 'measurement'
[13:14:48][C][max17048:036]: Unit of Measurement: '%'
[13:14:48][C][max17048:036]: Accuracy Decimals: 2
[13:14:48][C][max17048:037]: Discharge Rate (%/hr) 'Battery discharge rate'
[13:14:48][C][max17048:037]: Device Class: 'battery'
[13:14:48][C][max17048:037]: State Class: 'measurement'
[13:14:48][C][max17048:037]: Unit of Measurement: '%/h'
[13:14:48][C][uart.button:014]: UART Button 'Open GNSS data output'
[13:14:48][C][uart.button:014]: UART Button 'Warm restart GNSS'
[13:14:48][C][uart.button:014]: UART Button 'Get GPS fixed position'
[13:14:48][C][uart.button:014]: UART Button 'Get NMEA raw data 0.0'
[13:14:48][C][uart.button:014]: UART Button 'Get NMEA raw data 0.1'
[13:14:48][C][uart.button:014]: UART Button 'RESET MODULE'
[13:14:48][C][uart.button:014]: UART Button 'SCAN WIFI'
[13:14:48][C][captive_portal:089]: Captive Portal:
[13:14:48][C][mdns:116]: mDNS:
[13:14:48][C][mdns:117]: Hostname: cannondale-tracker
[13:14:48][C][esphome.ota:073]: Over-The-Air updates:
[13:14:48][C][esphome.ota:074]: Address: cannondale-tracker.local:3232
[13:14:48][C][esphome.ota:075]: Version: 2
[13:14:48][C][esphome.ota:078]: Password configured
[13:14:48][C][safe_mode:018]: Safe Mode:
[13:14:48][C][safe_mode:020]: Boot considered successful after 60 seconds
[13:14:48][C][safe_mode:021]: Invoke after 10 boot attempts
[13:14:48][C][safe_mode:023]: Remain in safe mode for 300 seconds
[13:14:48][C][api:140]: API Server:
[13:14:48][C][api:141]: Address: cannondale-tracker.local:6053
[13:14:48][C][api:143]: Using noise encryption: YES
[13:14:52][D][sensor:094]: 'Latitude': Sending state -1.00000 Ā° with 6 decimals of accuracy
[13:14:52][D][sensor:094]: 'Longitude': Sending state -1.00000 Ā° with 6 decimals of accuracy
[13:14:52][D][sensor:094]: 'Altitude': Sending state -1.00000 m with 1 decimals of accuracy
[13:14:54][D][button:010]: 'Get GPS fixed position' Pressed.
[13:14:54][D][uart.button:010]: 'Get GPS fixed position': Sending data...
[13:14:54][D][uart_debug:158]: >>> "AT+CGPSINFO"
[13:14:54][D][uart_debug:158]: <<< "AT+CGPSINFO"
[13:14:59][D][button:010]: 'SCAN WIFI' Pressed.
[13:14:59][D][uart.button:010]: 'SCAN WIFI': Sending data...
[13:14:59][D][uart_debug:158]: >>> "AT+CWSTASCAN"
[13:14:59][D][uart_debug:158]: <<< "AT+CWSTASCAN"
[13:15:01][D][button:010]: 'Get NMEA raw data 0.0' Pressed.
[13:15:01][D][uart.button:010]: 'Get NMEA raw data 0.0': Sending data...
[13:15:01][D][uart_debug:158]: >>> "AT+CGNSSPORTSWITCH = 0,0"
[13:15:01][D][uart_debug:158]: <<< "AT+CGNSSPORTSWITCH = 0,0"
[13:15:02][D][button:010]: 'Get NMEA raw data 0.1' Pressed.
[13:15:02][D][uart.button:010]: 'Get NMEA raw data 0.1': Sending data...
[13:15:02][D][uart_debug:158]: >>> "AT+CGNSSPORTSWITCH = 0,1"
[13:15:02][D][uart_debug:158]: <<< "AT+CGNSSPORTSWITCH = 0,1"
[13:15:03][D][button:010]: 'Open GNSS data output' Pressed.
[13:15:03][D][uart.button:010]: 'Open GNSS data output': Sending data...
[13:15:03][D][uart_debug:158]: >>> "AT+CGNSSTST=1"
[13:15:03][D][uart_debug:158]: <<< "AT+CGNSSTST=1"
[13:15:04][D][button:010]: 'Power on the GNSS' Pressed.
[13:15:04][D][uart.button:010]: 'Power on the GNSS': Sending data...
[13:15:04][D][uart_debug:158]: >>> "AT+CGNSSPWR=1"
[13:15:04][D][uart_debug:158]: <<< "AT+CGNSSPWR=1"
[13:15:06][D][button:010]: 'RESET MODULE' Pressed.
[13:15:06][D][uart.button:010]: 'RESET MODULE': Sending data...
[13:15:06][D][uart_debug:158]: >>> "AT+CRESET"
[13:15:06][D][uart_debug:158]: <<< "AT+CRESET"
[13:15:12][D][sensor:094]: 'Latitude': Sending state -1.00000 Ā° with 6 decimals of accuracy
[13:15:12][D][sensor:094]: 'Longitude': Sending state -1.00000 Ā° with 6 decimals of accuracy
[13:15:12][D][sensor:094]: 'Altitude': Sending state -1.00000 m with 1 decimals of accuracy
Iām wondering whether you might be better off first working through the provided device example demos (especially the ESP-IDF ones) to confirm your hardware is all set-up and working correctly with tested code before venturing into moving it to ESPHome?
I feel like the hardware interfaces and protocols between the various onboard hardware isnāt āobviousā (at least to me).
Anyone trying to support you here would need to read and develop a bit of understanding of your device, which would take them a little time.
I read the wiki from top to bottom, it helped me to implement the battery status sensor with help of one esp home recipe I found around.
However, ESP IDF is visibly advanced. I thought that ESP Homeās magic is in the simplicity of the implementation: nothing more than UART pins is not needed, the GPS component of ESP Home seems to be developed on the NMEA standards. Both in concert produce several sensors and voiala, everything else can be done in home assisstant. Thereās literally nothing special that one has to know if it were developed as expected. Or am I wrong and ESP home is not about the simplicity for people like me?
UART pins are certainly on 17 and 18. All documentations (Waveshare, ESP32-S3) says the same. What more do I need to get GPS readings?
and I am in the same situation. PINs are certainly correct, baud 115200 as well, it is written in the documentation and all receives are -1.00000. See below.
I do not see what else I can do better, maybe somebody knows?
INFO Reading configuration /config/esphome/esp32-s3-testing-1.yaml...
INFO Starting log output from 192.168.2.105 using esphome API
INFO Successfully connected to esp32-s3-testing-1 @ 192.168.2.105 in 0.106s
INFO Successful handshake with esp32-s3-testing-1 @ 192.168.2.105 in 0.057s
[18:43:24][I][app:100]: ESPHome version 2024.12.4 compiled on Jan 23 2025, 18:12:18
[18:43:24][C][wifi:600]: WiFi:
[18:43:24][C][wifi:428]: Local MAC: 64:E8:33:7D:F5:D4
[18:43:24][C][wifi:433]: SSID: [redacted]
[18:43:24][C][wifi:436]: IP Address: 192.168.2.105
[18:43:24][C][wifi:440]: BSSID: [redacted]
[18:43:24][C][wifi:441]: Hostname: 'esp32-s3-testing-1'
[18:43:24][C][wifi:443]: Signal strength: -74 dB āāāā
[18:43:24][C][wifi:447]: Channel: 4
[18:43:24][C][wifi:448]: Subnet: 255.255.255.0
[18:43:24][C][wifi:449]: Gateway: 192.168.2.1
[18:43:24][C][wifi:450]: DNS1: 192.168.2.131
[18:43:24][C][wifi:451]: DNS2: 192.168.2.1
[18:43:24][C][logger:185]: Logger:
[18:43:24][C][logger:186]: Level: DEBUG
[18:43:24][C][logger:188]: Log Baud Rate: 115200
[18:43:24][C][logger:189]: Hardware UART: USB_CDC
[18:43:24][C][uart.arduino_esp32:151]: UART Bus 0:
[18:43:24][C][uart.arduino_esp32:152]: TX Pin: GPIO43
[18:43:24][C][uart.arduino_esp32:153]: RX Pin: GPIO44
[18:43:24][C][uart.arduino_esp32:155]: RX Buffer Size: 256
[18:43:24][C][uart.arduino_esp32:157]: Baud Rate: 115200 baud
[18:43:24][C][uart.arduino_esp32:158]: Data Bits: 8
[18:43:24][C][uart.arduino_esp32:159]: Parity: NONE
[18:43:24][C][uart.arduino_esp32:160]: Stop bits: 1
[18:43:24][C][captive_portal:089]: Captive Portal:
[18:43:24][C][mdns:116]: mDNS:
[18:43:24][C][mdns:117]: Hostname: esp32-s3-testing-1
[18:43:24][C][esphome.ota:073]: Over-The-Air updates:
[18:43:24][C][esphome.ota:074]: Address: esp32-s3-testing-1.local:3232
[18:43:24][C][esphome.ota:075]: Version: 2
[18:43:24][C][esphome.ota:078]: Password configured
[18:43:24][C][safe_mode:018]: Safe Mode:
[18:43:24][C][safe_mode:020]: Boot considered successful after 60 seconds
[18:43:24][C][safe_mode:021]: Invoke after 10 boot attempts
[18:43:24][C][safe_mode:023]: Remain in safe mode for 300 seconds
[18:43:24][W][safe_mode:029]: Last reset occurred too quickly; safe mode will be invoked in 7 restarts
[18:43:24][C][api:140]: API Server:
[18:43:24][C][api:141]: Address: esp32-s3-testing-1.local:6053
[18:43:24][C][api:143]: Using noise encryption: YES
[18:43:40][D][sensor:094]: 'GNSS Latitude': Sending state -1.00000 Ā° with 6 decimals of accuracy
[18:43:40][D][sensor:094]: 'GNSS Longitude': Sending state -1.00000 Ā° with 6 decimals of accuracy
[18:43:40][D][sensor:094]: 'GNSS Speed': Sending state -1.00000 km/h with 6 decimals of accuracy
[18:43:40][D][sensor:094]: 'GNSS Altitude': Sending state -1.00000 m with 1 decimals of accuracy
[18:43:40][D][sensor:094]: 'GNSS Satellites': Sending state -1.00000 with 0 decimals of accuracy
[18:44:00][D][sensor:094]: 'GNSS Latitude': Sending state -1.00000 Ā° with 6 decimals of accuracy
[18:44:00][D][sensor:094]: 'GNSS Longitude': Sending state -1.00000 Ā° with 6 decimals of accuracy
[18:44:00][D][sensor:094]: 'GNSS Speed': Sending state -1.00000 km/h with 6 decimals of accuracy
[18:44:00][D][sensor:094]: 'GNSS Altitude': Sending state -1.00000 m with 1 decimals of accuracy
[18:44:00][D][sensor:094]: 'GNSS Satellites': Sending state -1.00000 with 0 decimals of accuracy
[18:44:20][D][sensor:094]: 'GNSS Latitude': Sending state -1.00000 Ā° with 6 decimals of accuracy
[18:44:20][D][sensor:094]: 'GNSS Longitude': Sending state -1.00000 Ā° with 6 decimals of accuracy
[18:44:20][D][sensor:094]: 'GNSS Speed': Sending state -1.00000 km/h with 6 decimals of accuracy
[18:44:20][D][sensor:094]: 'GNSS Altitude': Sending state -1.00000 m with 1 decimals of accuracy
[18:44:20][D][sensor:094]: 'GNSS Satellites': Sending state -1.00000 with 0 decimals of accuracy
[18:44:40][D][sensor:094]: 'GNSS Latitude': Sending state -1.00000 Ā° with 6 decimals of accuracy
[18:44:40][D][sensor:094]: 'GNSS Longitude': Sending state -1.00000 Ā° with 6 decimals of accuracy
[18:44:40][D][sensor:094]: 'GNSS Speed': Sending state -1.00000 km/h with 6 decimals of accuracy
[18:44:40][D][sensor:094]: 'GNSS Altitude': Sending state -1.00000 m with 1 decimals of accuracy
[18:44:40][D][sensor:094]: 'GNSS Satellites': Sending state -1.00000 with 0 decimals of accuracy
[18:45:00][D][sensor:094]: 'GNSS Latitude': Sending state -1.00000 Ā° with 6 decimals of accuracy
[18:45:00][D][sensor:094]: 'GNSS Longitude': Sending state -1.00000 Ā° with 6 decimals of accuracy
[18:45:00][D][sensor:094]: 'GNSS Speed': Sending state -1.00000 km/h with 6 decimals of accuracy
[18:45:00][D][sensor:094]: 'GNSS Altitude': Sending state -1.00000 m with 1 decimals of accuracy
[18:45:00][D][sensor:094]: 'GNSS Satellites': Sending state -1.00000 with 0 decimals of accuracy
[18:45:20][D][sensor:094]: 'GNSS Latitude': Sending state -1.00000 Ā° with 6 decimals of accuracy
[18:45:20][D][sensor:094]: 'GNSS Longitude': Sending state -1.00000 Ā° with 6 decimals of accuracy
[18:45:20][D][sensor:094]: 'GNSS Speed': Sending state -1.00000 km/h with 6 decimals of accuracy
[18:45:20][D][sensor:094]: 'GNSS Altitude': Sending state -1.00000 m with 1 decimals of accuracy
[18:45:20][D][sensor:094]: 'GNSS Satellites': Sending state -1.00000 with 0 decimals of accuracy
I do not see any UART debug related logs in the device log (the one I can open by clicking on ālogsā button of the device on the ESP home page of Home Assistant or the log I see after compilation).
If you think of the following example code, I do not know where the output is supposed to be.
# Example configuration entry
uart:
baud_rate: 115200
debug:
direction: BOTH
dummy_receiver: false
after:
delimiter: "\n"
sequence:
- lambda: UARTDebug::log_string(direction, bytes);
However, I tried presence sensor LD2420 for testing and made it work (for a while, then the sensor became unknown and I was not successful in ressurecting it). However, it proved me that I can configure UART.
I also tried a third different GPS module, same result with -1.00000 output, even after a lot of minutes under the sky.
ok, I think I am narrowing down the problem. UART works well without interruption on GPIO1 (TX) 2 (RX), instead of on the TX RX onboard pins (43, 44) for the presence sensor.
