Since my electricity meter in the basement cannot be connected to the WiFi, I use the iOKE868 Smart Metering Kit. It is connected to The Things NETWORK via LoRaWAN, which I have integrated into my Home Assistant.
Now I have an entity that alternately outputs the consumption and feed-in of a balcony power plant. I am wondering how I can assign these changing values to a consumption or feed-in sensor.
This is what the output looks like in json format.
For consumption
"OBIS_IDs": [
"GroupMask": 252,
"OBIS_ID": "1_0_1_8_0_255",
"Scaler": -1,
"rawValue": 101501104,
"unit": "Wh",
"value": 10150110.4
"general_info": {}
and for the feed-in
"OBIS_IDs": [
"GroupMask": 252,
"OBIS_ID": "1_0_2_8_0_255",
"Scaler": -1,
"rawValue": 24176,
"unit": "Wh",
"value": 24176.6
"general_info": {}
The values can be differentiated using the OBIS_IDs. How can I assign this to different sensors depending on the OBIS_ID?
Thank you for your help!
