How to read temperature from MAX31850K? Reading method does not work for MAX31850K the same as DS18b20. Thank you.
I used Appdaemon and python script:
mport appdaemon.plugins.hass.hassapi as hass
import os
import re
from glob import glob
import time
import datetime
from datetime import timedelta
class TEMPMAX31850K(hass.Hass):
def initialize(self):
interval_of_reading = 30
start_time = self.datetime() + datetime.timedelta(seconds = 1)
self.handle = self.run_every(self.read_and_set_temp, start_time, interval_of_reading)
def read_and_set_temp(self, kwargs):
fireplace_first_floor_temperature = self.read_temp("3b-4cc80984ea83")
fireplace_second_floor_temperature = self.read_temp("3b-2cc80984fc57")
states_fireplace_first_floor = self.get_state("sensor.fireplace_first_floor", attribute='all')
attributes_fireplace_first_floor = states_fireplace_first_floor['attributes']
self.set_state("sensor.fireplace_first_floor", state = fireplace_first_floor_temperature, attributes = attributes_fireplace_first_floor)
states_fireplace_second_floor = self.get_state("sensor.fireplace_second_floor", attribute='all')
attributes_fireplace_second_floor = states_fireplace_second_floor['attributes']
self.set_state("sensor.fireplace_second_floor", state = fireplace_second_floor_temperature, attributes = attributes_fireplace_second_floor)
# Function that reads and returns the raw content of 'w1_slave' file
def read_temp_raw(self, deviceCode):
w1DeviceFolder = '/sys/bus/w1/devices'
f = open(w1DeviceFolder + '/' + deviceCode + '/w1_slave' , 'r')
lines = f.readlines()
f.close()
return lines
# Function that reads the temperature from raw file content
def read_temp(self, deviceCode):
# Read the raw temperature data
lines = self.read_temp_raw(deviceCode)
# Wait until the data is valid - end of the first line reads 'YES'
while lines[0].strip()[-3:] != 'YES':
time.sleep(0.2)
# Read the temperature, that is on the second line
equals_pos = lines[1].find('t=')
if equals_pos != -1:
temp_string = lines[1][equals_pos+2:]
# Convert the temperature number to Celsius
temp_c = float(temp_string) / 1000.0
# Return formatted sensor data, round to 1 decimal number
return round(temp_c, 1)
